Making a carbon fiber robot "hand"
Likes Likes:  0
Results 1 to 4 of 4
    Sep 2015
    Tennessee
    569
    281
    436
    Default Making a carbon fiber robot "hand"
    I need some help with a supplier, and any tips if someone has done this before.
    We're trying to install a collaborative robot into our metal finishing process. The robot will take a part (think flat/sheet profile) and place it on a fixture inside a laser etcher. The robot has a payload of 10kg and the heaviest part it will lift is 4kg. On test runs the robotic engineer we have designed a hand out of aluminum which basically looks like this:
    However, there's a lot of "quiver" at the very ends of the prongs, which is unwanted. So, since they gave it to me, I'm going to use carbon fiber tubing and plate. Much much stiffer, and lighter. Has anyone created a fork/hand/fixture for a robot out of carbon fiber that has some tips? Most importantly I'm looking for a good vendor for the tubing.
    Oct 2014
    CANADA
    Ontario
    1,445
    993
    1195
    If the part is shaped like a sheet, wouldn't it be more reliable to use a vacuum lifter or something similar on it? Something like this:
    The page I pulled that image from has more info regarding the PLC and components used for that end effector: Pick and place using pneumatic vacuum pads |
    Jul 2010
    Wisconsin
    451
    325
    Quote Originally Posted by Rewt View Post
    We drill the sheet with brad point carbide drills, and glue the tubes into aluminum bases with loctite 9340 adhesive.
    We have bought CF from McMaster-Carr, but have found cheaper with a google search.
    Sep 2015
    Tennessee
    569
    281
    436
    Quote Originally Posted by aarongough View Post
    The part has been formed in a press so doesn't have enough flat spots, also we cannot touch the top surface.
