Xjenderfloip
Stainless
- Feb 9, 2005
- Rotterdam
Hi im looking for ideas to avoid buying a robot interface from mori seiki.
We got a mori and a used fanuc robot, now to get the communication between the 2, we would have to buy one for $12.000, wich is more then we paid for the robot hehe.
The boss is getting tight with the budget now so...
The robot has to pick and place parts, so theres not so much need for alot of I/O , i think 5 of each will do.
As far as i can see this will be the sequence.
Start program
Finished machining
Open door (by automatic door or robot)(signal out to robot)
Place robot grippers on part
Open chuck (signal in to CNC)
Put machined part on table
Get&place new part
Close chuck (signal in to CNC)
Check for closed chuck(signal out to robot)
Remove robot
start program(signal in to CNC)
What are the options?
Are there any companies that make generic I/O cards and provide help and support plugging it into a mori (2007 build) ?
Forget the I/O and use the signal lamp, circuit break the green button and foot pedal ?
Are there any free programmable M-codes and I/O ports on a MSX 850III ?
Any toughs are welcome
Start program
Finished machining
Get&place new part
Remove robot
