Need help with building a custom pneumatic press
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Sep 2019
    South Carolina
    41
    19
    Default Need help with building a custom pneumatic press
    Looking to build something like in the video below (11:08) but with dual pistons if possible (is that possible to do and have them sync up?)
    Want to build this for dual purpose... For pressing Kydex sheaths or using with 1" thick aluminum slabs for quench plates when heat treating blades.
    I'm thinking 1/2 ton for pressure but would be nice to have it variable... Not sure if it's best to incorporate air into this design or just make it electric?
    I need it to press and hold for a few minutes.
    Thoughts?
    11:08 in video
    YouTube
    Jul 2008
    Philadelphia
    2,005
    538
    462
    I would begin by assessing what you have in the shop work with. If ya have plenty of air good, just remember air one expensive commodity in the shop. Simple would be an apparatus like in the vid, just sit a bottle jack in the middle of the basal platen.
    Apr 2019
    Arkansas
    1,292
    566
    492
    Quote Originally Posted by razoredgeknives View Post
    Thoughts?
    11:08 in video
    YouTube
    pneumatic work great or you can always electric hydraulic. Units can be had cheap on ebay and the cylinders are also fairly cheap used.
    Mar 2009
    Eureka, CA
    3,965
    831
    1455
    My two cents. Dual pneumatic cylinders would be problematic, hard to keep together and regardless of the guide rods would inherently try to bind. A simple 4" cylinder at 120 psi gives you 1500 pounds of squish and that would be adjustable (down) with air regulation.
    It would be a fun and simple build in my book.
    Stuart
  5. Likes BugRobotics, Zach201, 76Harley liked this post
    Jan 2012
    Florida
    177
    188
    63
    I built one some yrs back with two cylinders they never extended the same but once the first cylinder
    reached resistance the second would catch up and equalize.
    the only issue was speed I could not regulate speed without compromising force ,that is without a lot of solenoids and valving
    It did what I need no problem
    not too overly complex
    Feb 2010
    IN, USA
    259
    7
    271
    That's a trivial thing to build and would work fine. Hell, I've got everything laying around the shop from old jobs. A 100mm bore cylinder would give you right at 1/2 ton. I'd go with 125mm bore (giving you about 7/8 of a ton) and use a pressure regulator to control the force. Unless you plan to automate it I'd use a simple hand operated pneumatic valve like a Festo VHER. Flow controls to control the speed and you're done.
    Feb 2016
    South Carolina
    9
    Quote Originally Posted by doug8cat View Post
    yeah I've got a 7.5hp Eason compressor, it should be plenty of air. although I do have a regular right out of the compressor setting air to 100psi, I can certainly up that to like 130-150 if needed.
    Quote Originally Posted by as9100d View Post
    the electric hydraulic (from looking on ebay) look like a lot more pressure than I will need... they are massive lol. I just need like a 1 ton or something similar
    Quote Originally Posted by atomarc View Post
    Stuart
    Yeah maybe I'm overbuilding. I want to use it for quench plates w/ 1" thick aluminum plate on each side (top and bottom) and just didn't want higher pressure in the middle of the plate vs. the sides.
    I saw this on Alibiba, about $800. may be about what I need but not sure.
    Quote Originally Posted by ernieflash View Post
    Makes sense... yeah I don't want it to slam down on to the blades. Not sure what to do here.
    Quote Originally Posted by Punkinhead View Post
    Oh man thanks for your help! Yeah I may keep it single cylinder. Now I need to comprise a list of what to get. What do you think about these items?
    - air cylinder: this looks like the largest they have of this type
    - regulator
    - it looks like the Vher levers don't have 3/8 npt which is what the two above units use... should I convert to 3/8 or look for something else?
    The way it's set up in the video is with a regulator, a two way switch for up/down and then a pair of actuator buttons in series so you have to use both hands to actuate it according to the knife maker in that video. I don't have to set up mine exactly like it but just trying to figure out what to do. I'm pretty new to building stuff like this.
  9. #8
    Mar 2009
    Eureka, CA
    3,965
    831
    1455
    A bit confused here..a different member name replied, are you using two screen names?
    In regards to the press pictured through Alibaba, I would run screaming from that, pneumatics are not a exact science and those cylinder will not extend or retract in perfect time. The skinny little guide bars with take a dump in a heartbeat when things go sour, plus if you don't load both side of the press identically the cylinders will try to cant/tilt the press plate and again, things go sour. The picture looks cool but the engineering is..'fake news'!
    Stuart
  10. Likes razoredgeknives liked this post
  11. #9
    Oct 2014
    Maine
    1,057
    154
    501
    Why don't you just copy Aaron's press? If you're concerned that the plates will deflect, make them thicker.
  12. #10
    Oct 2014
    CANADA
    Ontario
    1,430
    966
    1180
    As the others have said I think a single cylinder with a larger diameter would be much easier and work better! My press generates less than 500# if I remember correctly so anything north of this should work fine for you! I don't think you'll need much pressure for the quench plates, and you definitely don't need a whole lot for thermoforming kydex as it's pretty pliable when it's hot. Too much pressure and you'll just crush the life out of your foam and reduce it's lifespan.
    Also one tip: normal neoprene foams that are commonly used in kydex presses don't work so will in this application, because of the high clamp force it tends to bond to the hot kydex and start breaking down quickly. I use a layer of silicone rubber foam on top of my neoprene foam as a release layer and it has been holding up perfectly!
  13. Likes razoredgeknives, 3t3d liked this post
  14. #11
    Oct 2005
    17,688
    They make (or you can fudge your own) multiple cylinders end to end,
    so the force is thru one rod.
  15. #12
    Sep 2019
    South Carolina
    41
    19
    Stuart
    sorry yeah that's an old/personal account, didn't meean to do that. and thanks, that's great info, I really appreciate you looking out for me!
    Quote Originally Posted by DanielG View Post
    Am working on it, would love to!
    Quote Originally Posted by aarongough View Post
    man great to see you here to help out Aaron! you're the man bro.
    Did you get everything from mcmaster?
    great tip on the silocone rubber roam... how come you don't use it in place of the neoprene foam? not moldable enough?
  16. #13
    Oct 2014
    CANADA
    Ontario
    1,430
    966
    1180
    Yeah pretty much everything was from McMaster... The silicone rubber foam is much more expensive so I saved some money by just using a 1/2" layer of it. I don't think there would be any issue with using a thicker layer. I just went through my McMaster orders from the period around where I built the press, here are the part numbers for the various components:
    Silicone foam: McMaster-Carr
    Pneumatic cylinder: McMaster-Carr
    Up/down switch: McMaster-Carr
    Hand switches (x2): McMaster-Carr
    Regulator: McMaster-Carr
    Push to connect fittings: https://www.mcmaster.com/5779k283 - https://www.mcmaster.com/5779k109 - https://www.mcmaster.com/5779k151
  17. Likes DanielG liked this post
  18. #14
    Mar 2009
    Eureka, CA
    3,965
    831
    1455
    In the original post you stated you wanted about 1000lbs of force. The 2 1/2" cylinder noted above, even at 120 PSI will only give you about 590lbs of force.
    Stuart
  19. #15
    Sep 2019
    South Carolina
    41
    19
    wow thanks so much for that!! HUGE help
    Stuart
    So true! I'll see about getting the next step up. I'm honestly not sure how many lbs of force I need for quench plates... that may be enough.
  20. #16
    Sep 2019
    South Carolina
    41
    19
    Question... how come you went w/ 2 hand switches vs only one? Will one work?
  21. #17
    Oct 2005
    17,688
    It's a powered (as opposed to a hand powered) press, hence the 2 hand switches.
  22. #18
    Oct 2014
    CANADA
    Ontario
    1,430
    966
    1180
    Yeah, two hand switches to reduce the chances of accidentally squishing a digit or two...
  23. #19
    Nov 2004
    WI
    4,747
    517
    1105
    With Two switches, you don't have an extra hand getting squished.
    With One switch, you could have the other hand getting squished.
  24. Likes HiNi liked this post
  25. #20
    Oct 2005
    17,688
    Actually, to satisfy OSHA, you need :
    Two-Hand Anti-Tie Down
    "Anti tie down 2 hand control"
