Pneumatic cylinder on a 4th axis questions
Results 1 to 17 of 17
    Apr 2019
    Arkansas
    111
    7
    41
    Default Pneumatic cylinder on a 4th axis questions
    I need to use a miteebite id expand clamp that's centered om a fixture mounted to a Haas rotary table.
    Ideally I'd like to use a bima thin pneumatic air cylinder to push and pull the bolt.
    Can these cylinders take positional rotation movement or am I going to have to come up with some kind of rotary union or other method?
    Jun 2006
    PA
    561
    14
    29
    For most typical pneumatic cylinders, you can buy rear pivot mounts.
    Also, you can buy round body cylinders with a hole in the rear mount that you can use as a pivot.
    Do a search in Mcmaster Carr for round body air cylinder and you'll see some options.
    btm
    Apr 2019
    Arkansas
    111
    7
    41
    I know the cylinder I want to use. Just need to know if it can support turning the shaft on a 4th axis.[
    ATTACH=CONFIG]263423[/ATTACH]
    I want to mount this to the back of the 4th axis device with a threaded rod going up to my fixture that had an Id expand clamp in the center.
    This is the quicky fixture that was made for the sample parts. I'm just trying to automate the miteebite Id clamp/unclamp
    Jul 2006
    Hillsboro, New Hampshire
    7,003
    1651
    4824
    My gut says yes for limited, low speed use, but then my gut says yes to large quantities of pie. Clearly can't be trusted...
    Instead of setting up a rotary air joint, you could go the other way and set up a taper roller bearing at the rod end, with a "over sleeve" that takes you to acting on the miteebite. I've done such things when needed, and while a little more work, is reasonably reliable as long as you account for chip protection.
    Apr 2019
    Arkansas
    111
    7
    41
    Have any photos?
    Dec 2007
    Southeastern US
    6,400
    845
    2802
    For a run of a few thousand pieces, should be ok. I would have a spare cylinder on hand though as it may develop internal blowby as the seals wear.
    Apr 2019
    Arkansas
    111
    7
    41
    What do I need to do for say 20,000 pieces. Rig a dual passage rotary union??
    Nov 2004
    WI
    4,676
    437
    1067
    Can you limit the rotary table Wind up?
    That would solve your problem.
    Apr 2019
    Arkansas
    111
    7
    41
    I can and had thought about that. I'm on the hunt for an inexpensive 2 passage rotary union
    Jan 2019
    Arizona
    533
    36
    186
    Quote Originally Posted by as9100d View Post
    Find and old Hardinge AHC collet closer( or somethign like that) and modify it. it should work just fine.
  11. #11
    Jul 2006
    7,003
    1651
    4824
    Have any photos?
    Last time I did this was a while ago, and unfortunately there's no pics of it.
  12. #12
    Feb 2005
    Akron, OH
    1,812
    272
    1353
    Overthinking it.
    Spin the cylinder, spin the connector, take up the rotation in the air line. A couple feet of 1/4" polyurethane tubing won't even notice one rotation.
    Be careful not to wrap up when programming.
  13. #13
    Feb 2012
    1,334
    873
    1427
    Manually actuated screws generate a lot of force even at low torque. For example, a 3/8" screw at 40 ft lbs generates 6400 lbs of axial force.
    Bolt Torque, Axial Clamp Force, Bolt Diameter Calculator | Engineers Edge| www.engineersedge.com
    The calculator is imperfect, because coefficient of friction varies a lot (difficult to estimate), and it doesn't take thread pitch into account, nor the grade of screw, but it's at least within the ballpark.
    Even a big 4" ID, 5.25" OD pancake air cylinder @ 150 psi only generates 1886 lbs of force. I think for your application, you're going to want to go hydraulic:
    Vektek: Products: Hydraulic
  14. #14
    Dec 2003
    Washington
    4,627
    2129
    3918
    Expanding bore clamps typically use a shallow taper - as such the clamping force is a multiple of drawbar force . . . If you don’t want to be concerned with wind up or chafing of your lines, we use Deublin Rotary unions in applications like this.
    Idev Listing | Deublin Company
  15. #15
    Apr 2019
    Arkansas
    111
    7
    41
    Quote Originally Posted by Comatose View Post
    Overthinking it.
    I had thought to go hydraulic however the parts are hdpe/ACETAL so clamping forces are lower.
    What are your thoughts of I'd clamping with plastics.
  16. #16
    Aug 2016
    Ohio
    27
    25
    20
    I use these same cylinders as a "tailstock" to hold (push)injection molded parts on a 4th. IME the cylinder can handle indexing without much issue. We've replaced 1 or 2 since 2017, but that has to do with the small plastic chips getting inside and fucking up the seals. That's thousands and thousands of indexes, 2 shifts, 5 days a week. Pop them open and grease them up and they're good to go again!
  17. Likes J Gilles liked this post
  18. #17
    Apr 2019
    Arkansas
    111
    7
    41
    Quote Originally Posted by DFrench View Post
    Perfect. That will work better than an I'd expand clamp anyways!!
