Source of good quality camera for inspection line
Results 1 to 14 of 14
    Jan 2005
    Lockport, NY
    597
    7
    8
    Default Source of good quality camera for inspection line
    We need a good industrial camera for inspecting something that can resolve 50 microns or so through a C mount lens. Who are the top 3 names in this kind of thing? It looks like Canon gets involved in this kind of thing (although Nikon appears more involved in microscopy). Any thoughts or recommendations? Are there any reputable forums on this subject? I did a search here an not much came up. Not sure if I need "machine vision" as we are doing visual inspection but magnifying it and displaying it on a large video screen. We would use a macro lens, possibly C mount if the quality is good enough for the sensor used.
    Jan 2007
    Flushing/Flint, Michigan
    10,282
    590
    8384
    Edmunds optics.
    Get the catalog and tech info.
    You say 50 microns but do not say size of the part to be imaged. Is this .002 thou a pass fail limit? if so do you need a lot inside at the image for good/bad judgment?
    This is can get complicated, is your display screen up to the task? Frame rates? Need telecentric or somewhat?
    I'll ask these things of people and 98% of the time I get a blank stare as if I'm am talking Martian.
    Be aware that color cameras and black and white cameras are very different in actual resolution vs pixel count.
    Welcome to a rabbit hole. I am not aware of any good forums on this so if you all out there have one please post.
    Bob
    Jul 2005
    central Illinois
    257
    1197
    101
    Don't know if it's helpful to you, but I've learned a lot from Machine Vision magazine. Machine Vision Mag | Led illumination for Machine Vision, all you need to know
    Jan 2005
    Lockport, NY
    597
    7
    8
    Carbide Bob:
    I am an amateur photographer with a degree from Google U. so I know a little.Also I am a mechanical engineer with a bit of machining knowlege. Also, we used to shoot high speed video out at the WSL at China Lake so here are my assumptions, please correct me if I am wrong:
    1. The application is looking for contamination in a volume of space.
    2. We have defined the needed depth of field and width of view and used a nifty calculator for depth of field and married it to smallest circle of confusion that will enable us to use up our inspection volume. The entire inspection volume is to be checked. See this link: Online Depth of Field Calculator. Our circle of confusion is down around 15 microns (theoretical of course, the real world is full of toleranced lenses, cameras, screens, etc)
    3. When shooting high speed video(flashback to the Weapons Survivabiltiy Laboratory at China Lake) the application engineer told me if I gave up color imaging and went to black and white I could get more resolution. Is that generally true?
    4. We are NOT recording video, the inspector merely views what they are inspecting.
    5. I am being deliberately cagey about the "inspection volume" as I don't want people to know what technology we are developing. Lets just say its smaller than a breadbox but bigger than a TV remote. I don't even want to say what industry this is for, its that sensitive.
    Jan 2007
    10,282
    590
    8384
    #3
    Camera photosites only count photons, they know nothing about color.
    To make color you but a Bayer filter in front of the chip. The input from the set (a R site, a B site, and a G site) give a colored pixel. (Google this)
    In fact you have just divided the camera resolution by 3. Software in the camera then interpolates to out the specked resolution number but a lot of these pixels are made up information.
    Also alignment of this "color mask" to the chip sensor is never perfect so some loss there.
    Almost all cameras except the ultra big buck scientific stuff will have some dead pixels. Again software in the camera guesses at what should be output.
    This means that if a feature is only one pixel in size there are places in the FOV where you will never see it or detect it.
    On top of this there is a thing called "fill factor" for different sensor types. Unlike film not all of the sensor front is photosensitive.
    A single feature, say a floating piece of dust needs to be at least 3x3 pixels in B/W and 7x7 in color to be seen reliably.
    High resolution sensors need to pump a lot of data and the interface is a real speed limit. Real time viewing of a 14MP camera on USB3 is a problem. Higher speed interfaces go up in price fast.
    Also monitor resolution in such a setup. In between the camera stream and the monitor output some scaling normally goes on. This can make small things disappear or grow.
    If you do have the bandwidth and a 8K monitor how small a displayed feature can your human reliably see? How big is the pixel on the monitor becomes a question.
    You are going to need to do some experimenting pushing hard to look at worse case.
    This is where many fail. They want it to work so on the bench get something great only to have it not work so great 30-60% of the time in the field.
    Try to make it fail, not to make it work.
    Unsure the application but is stared at long enough there is the garbage man problem. A garbage man does not smell garbage anymore.
    A continuous visual inspector does not see the 1 in 1000. If over and over the brain fills in or filters the information. That a whole another story and studies.
    I do not know what you are doing or if any of this is worth posting here but my 2 cents worth as I do so like video inspection.
    Yes I for sure know some sense and no sense here. A rabbit hole of senors, display, and humans viewing it.
    It is a system and weakest link.
    Bob
  6. Likes TeachMePlease, AndyF liked this post
    Jan 2005
    Lockport, NY
    597
    7
    8
    Dear Carbide Bob,
    Thanks, this is eye opening. I know I have a lot to learn. I didn't know 8k was a thing for monitors OR cameras. Wow, just wow.
    Jan 2005
    Lockport, NY
    597
    7
    8
    OK, I found some cameras. I'm looking at
    1.Amscope
    2.Thor Labs
    3.Baseler
    4. Pixelink
    5. EdmundOptics (Edmund Scientific)
    All are 1/3" or 1/2.5" cameras.
    Edmund seems to hit the sweet spot with a 1/2.5" CMOS with 5 megapixels for 310 bucks. They sell Allied Vision cameras.
  9. #8
    Jan 2005
    Lockport, NY
    597
    7
    8
    Update:
    Looking at a 4k camera, direct to monitor via HDMI by Accu-Scope. Using Navitar lenses or Fujninon on demo.
  10. #9
    Dec 2007
    Southeastern US
    6,420
    877
    2847
    If you want to automate the decision process, then Cognex or Keyence would be the first 2 places I would go. We use a considerable number of both in our manufacturing facility.
  11. Likes Conrad Hoffman liked this post
  12. #10
    Jan 2005
    Lockport, NY
    597
    7
    8
    We are not automating at this point, we are just using a large 4k monitor to assist visual inspection by humans. We talked to Keyence and their camera alone is over $5k. We can get cameras of equivalent value for under $2k using Sony Chips.
    However, thanks for mentioning Cognex, maybe they could come out here too.
  13. #11
    Feb 2005
    Akron, OH
    1,992
    328
    1521
    Basler and Flir would be the manufacturers I'd look at first if all you need is a dumb camera.
  14. #12
    Jul 2014
    Michigan
    27
    7
    Default Add light
    Quote Originally Posted by Neil View Post
    Update:
    We make camera systems for some specific industrial inspection processes. Most systems have a resolution of 1080p because that is adequate for a direct display solution. Currently HDMI output 4k cameras are the most cost effective as you don't have a computer. They will work fine but may not last for years as they run hot. Also, distance from camera to display can be an issue with HDMI.
    As far as lenses go it all depends on working distance and field of view. Do you ever want to change these parameters? Lighting (strength/direction/type) as related to the reflectivity of the material, geometry and distance are your next considerations. Entocentric lenses would be fine for what you are talking about but if you ever measure you might consider telecentric.
    For our soldering station we purchased a 1080p chinese microscope camera a few years back for $500 which has an autofocus feature and put on a Kowa macroscopic lens. The image is good enough, but the on screen display can be a bit annoying. Rather than an autofocus, you may consider a smaller iris size and adding more light for greater depth of field. In general for this application a smaller sensor size would allow for smaller lenses, which can be helpful.
  15. #13
    Jul 2014
    Michigan
    27
    7
    I should have also said you can run some of the machine vision cameras via linux .. you'd need something better than a raspberry pi to run 4k
  16. #14
    Apr 2021
