I'm trying to set up a light curtain unit for the first time, it is used equipment that has been sitting for a while. I followed the instructions in the photo, but it does not seem to be setting up correctly. If I switch to RESET the blocked LED is always lit, no matter where I adjust the pot to. If I adjust the pot all the way CCW (its a multi turn pot) and then adjust CW till the clear light goes green, both lights remain lit when I switch back to OPERATE and blocking or misaligning the transmitter and receiver do nothing other than changing the brightness of the alignment LED. the blocked LED ia always lit, no matter what. Any tips for setup?
