as9100d
Stainless
- Apr 19, 2019
- Paris, Arkansas
What I have is a part thats roughly 4"x4" x 1.15" Made of Acetal. The outside 4 edges get 1 hole dead center of all axis. The drilled hole is all the way to the center of the part where they converge into a 1/2" center hole.
We make some 5000 of these a month and while op1/2 arent that bad, the last op for the 4 holes on the 4th axis take up the most real spindle time because of the load/unload and rotations.
What I want to do is remove this last op from the $100,000+ cnc machines and move them to a machine I can build for about $4000 in materials not taking into account the labor, I have several projects that could use this type of automation and will look at the labor as a trade off for learning.
What im struggling with is wrapping my head around a way to load and position the material via conveyor or other cheap method other than a person manually loading and unloading this machine.
I will purchase 4 er11 1.5kw spindles and vfd drives to power the 4 drills. Then I will make some ball screw driven axis that move those spindles.
Any of you fine folks ever gone down this road and have photos to share?
