Time to build a machine to automate a process, Anyone want to help my first journey? - Page 3
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 41 to 60 of 161
  1. #41
    Jun 2015
    490
    106
    128
    Quote Originally Posted by TDegenhart View Post
    the melt temperature must be higher ..
    And with that the molecular weight of the plastic gets reduced and the mechanical properties go with it.
    Real mold shops don't make molds out of AL. Protomold makes them out of AL but they don't promise they'll last very long. I can't imagine they'll hold tolerances as well either considering they expand more.
  2. #42
    Jul 2012
    Washington
    3,015
    1191
    1254
    Quote Originally Posted by CosmosK View Post
    Having both made and run, for years, molds made of both materials aluminum is hands down the best material to make molds from. It will draw heat from the part much faster for faster cycle times, and coolant channels are not as critically placed in the mold to avoid hot spots. A good aluminum mold for this part should easily make 500,000 parts. Sure if you abuse it or run wet plastic the life span will drop but the same applies to steel.
    TDegenhart, have you ever run chemical foaming agent? The stuff is like magic fairy dust for a part like this. The only downside I ever noticed with it was the material can get kinda sticky in the hopper when drying above 220f for longer periods of time.
  3. #43
    Apr 2019
    Arkansas
    1,033
    392
    375
    I found a video for the CFA, it really is the magic fairy dust for this part. Im not sure how I would get that to work with an older machine though. I dont know if those old machines have the ability to pull back slightly to chemically form the airbubbles in the center of the part.
  4. #44
    Jul 2012
    Washington
    3,015
    1191
    1254
    Quote Originally Posted by as9100d View Post
    We only had a 1992 200 ton press and it worked fine. We only had boost and hold to play with, nothing at all fancy that computer controls brought.
    How much does a finished part weigh?
  5. #45
    Jun 2015
    490
    106
    128
    Quote Originally Posted by DavidScott View Post
    Ok, I respect your take on it. I will ask my neighbor (mold shop) next time I get a chance. I have my doubts Back when I was working with injection molded parts, the molds were all EDM'd tool steel. We farmed out mold making and molding as they are businesses in and of themselves.
  6. #46
    Apr 2019
    Arkansas
    1,033
    392
    375
    204 grams with no outside perimeter holes.
  7. #47
    Jul 2012
    Washington
    3,015
    1191
    1254
    Don't talk to mold makers as they don't know how to run a mold, talk to the people running them. I worked for a sailboard components company that bought their own press to do it in house so I got to do it all. Keep in mind when I say aluminum for plastic injection molds I specifically mean Alcoa QC-7, nothing I have ever worked with compares, it too has magic fairy dust in it. The same compressive strength of annealed 4140 with the same thermal conductivity of 6061. Although I have seen some 6061 molds with 1/4 million shots that had had a hard life but still made good parts so don't say it won't work.
  8. #48
    Apr 2019
    Arkansas
    1,033
    392
    375
    I think the important part to remember is I have an entire cnc machine shop. Sure we arent making molds and I know its an art but so is everything else we make for aerospace and dod.
    I vote for Aluminum, ive seen tons of injection molds made of aluminum that work just fine and really...if it wears out we can just make another one. If the design is jacked up, its cheap to make another one and fast because of the material.
    There are a few critical dims that have to be had, 1 is an OD boss with a thin wall/feature that has to have +/- 0.002 on the OD. In the center of that is a through hole that has to maintain the same tolerance.
  9. #49
    Jul 2006
    Hillsboro, New Hampshire
    8,518
    2057
    5923
    David, I looked for more information on the "QC" series of Al mold materials, and all I found was info for QC-10. (like https://www.yarde.com/docs/products/QC-10_brochure.pdf). Are the -7 and 9 materials older versions of what's now -10, or are they different and still available on their own?
  10. #50
    Jul 2012
    Washington
    3,015
    1191
    1254
    I think they are the older versions of 10. I left mold making in 97 so it's been awhile.
  11. Likes Milland liked this post
  12. #51
    Jul 2006
    8,518
    2057
    5923
    Here's another reference on using Al mold materials: https://www.arconic.com/mold/en/pdf/spiral_report.pdf
    "Why Plastic Flows Better in Aluminum Injection Molds"
  13. #52
    Mar 2011
    Geneva Illinois USA
    6,347
    2750
    2469
    The three holes on the top surface (in addition to the central hole) are these through holes? If they are then sensing orientation is simple. One place on the conveyor has an LED light one one side and a sensor on the other. If light goes through, the part is oriented. If not, either stop the conveyor or kick off the part off or have an "orientor". The orientor could be nothing more than a table the part sits on that can be rotated 90* with a air cylinder. It rotates one step at a time until the part passes light.
    As to the locating in the drill nest, you have a better of how to to do that than I as you have the part and know the tolerances on each feature. I was just agreeing with Robert R that the best way was to load from below.
    Tom
  14. #53
    Apr 2019
    Arkansas
    1,033
    392
    375
    They are not through holes sadly. However, there is a dimple next to one of the hole. Ill post a photo here in a bit.
  15. #54
    Mar 2011
    Geneva Illinois USA
    6,347
    2750
    2469
    Can a through hole be added just for orientation?
    Tom
  16. #55
    Apr 2019
    Arkansas
    1,033
    392
    375
    Nope. The part cannot be changed. It's an oem replacement part
  17. #56
    Mar 2011
    Geneva Illinois USA
    6,347
    2750
    2469
    Check with Keyence. These people make all manner of sensors. I am sure they have something reasonable to sense orientation. My experience with them has been very positive. I can't tell from the photo, is the feature by your finger recessed for protruding? Either way, I believe a light beam and sensor can pick it up. Also short range ultrasonics. Are you planning on a PLC for the machine?
    Tom
    edit another problem to be faced is with the current setup, other than a broken tool, you have little or no quality issues. With the off line drill, orientation and positioning will be a quality problem unless addressed up front. Unfortunately this cannot be a quality audit as potentially every part could be different.
  18. #57
    May 2011
    New Jersey
    2,422
    213
    1309
    The molding idea sounds unfeasible and the home built machine sounds like a dream turned money pit/time sucker. I'd be looking at ways to use what I currently have available to do this. If ganging them up is a realistic option I might would start there. I will say, it's a bit of a unique issue, mainly based on quantity throughput.
    Or maybe, as said earlier, it's just the nature of the beast.
  19. Likes motion guru liked this post
  20. #58
    Apr 2019
    Arkansas
    1,033
    392
    375
    Tom
    Absolutely on the plc. This is what I bought so far.
    Products | Velocio.net
  21. #59
    Apr 2019
    Arkansas
    1,033
    392
    375
    People said the same thing to Henry Ford and well we see how that turned out.
    That said, I know you don't know my capabilities or my shop but I'll say this. I have 30 Haas Mills and 10 robodrills along with a few lathes and 5 screw machines. Lots of automation already taking place with fanucmate 200id robots tending robodrills.
    I don't know how feasible it is for injection molding these, but....I do know building a dedicated machine for drilling holes isn't something that people aren't doing...
    I have a part I can do 60,000 pieces a year on....why is it so crazy to want to automate the most expensive part of the manufacturing process?
  22. #60
    May 2011
    New Jersey
    2,422
    213
    1309
    I don't think it's crazy, I'm sure it's possible, but is there a better, more cost effective way to meet the goal.
