Best current source for multifix tool holders in Europe - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21
    Mar 2012
    Geilenkirchen, Germany
    2,578
    1517
    1313
    I just noticed on checking my link, are you the "SteveI" on this model engineer forum?
    David[/QUOTE]
    No David, I am not the same.
    Steve
  2. #22
    Apr 2018
    CANADA
    British Columbia
    I just bought an A size set of Multifix QCTP parts from Create Tool. All but the threading tools but those are also available. I havn't used them yet but the parts look and fit fine. The challenge was figuring out what size to buy. I am going to use a spacer plate on the cross slide. After getting the parts and considering a range of tool sizes I decided I need 30mm between the base of the tool post and the centre line of the lathe.
  3. #23
    Apr 2002
    Central Mother Lode, California
    836
    1041
    111
    Quote Originally Posted by Wet Coast Canada View Post
    Following on my earlier posts as well as this one, I recently bought a size A Multi-Suisse tool post and assorted holders (including external threading and cut-off holders) directly from SRW Amestra. I then ordered some additional A 2090 tool holders from Create; Amestra and Create use the same numbering system for their tool holders. The Create A 2090 tool holders are as nicely made as those from Amestra. OK, I didn't do hardness testing on any of these nor have I used them for thousands of hours each yet. The height adjusting screws and the square head screws interchange. The Create holders tighten up at the same point on the tool post as those from Amestra.
    Indeed the Amestra and the Create A 2090 holders look quite similar, including some cosmetic details, to the point that I wouldn't be surprised to find that they were from the same maker. Neither is marked with a brand name or a country of origin. The tool post itself is labeled:
    "ORIGINAL MULTI SUISSE
    -A-
    SRW AMESTRA Gmbh"
    David
  4. #24
    Apr 2005
    Maine
    345
    26
    21
    Good to see this informative thread on the Multifix toolposts.
    I purchased two Mulifix ED 20100 holders way back in the "glory days" of eBay when it was primarily an auction site and much friendlier to sellers. The selection and pricing were much better back then.
    Both were brand new in SPI boxes (SPI part No. 71-251-3). I assumed they were Swiss. One of the two is stamped "ORIGINAL MULTI SUISSE". The other is not, and otherwise they are identical (except for a number stamp on the bottom that may be a production date).
    Later I bought an EFI internal threading holder and noticed it was stamped "Made in Switzerland". All this was academic since I did not have the toolpost, nor a lathe big enough to take advantage of the "E" Multifix (at the time I only had my Schaublin 102N).
    Once I acquired a Hardinge HLV-H, I felt I had a need to put the Multifix E to use, primarily to use my Val-Cut trepanning tool, which has a 22mm shank. I was able to source a NOS Multifix E Toolpost from a member on this site. The badge on the side of the toolpost reads:
    ORIGINAL MULTIFIX SUISSE®
    -E-
    MIVESA Made in Switzerland GENEVE
    Here is what I've noticed: The Swiss made EFI holder slides in and clamps perfectly. The SPI holder marked "ORIGINAL MULTI SUISSE" fits very tightly (the lever moves slightly for closing). The other SPI holder without the stamp fits very VERY tight. You can barely slide it down the splines and the handle can barely move.
    If anyone has any suggestions I would appreciate hearing them. I've had it suggested to improve the fit on the tight ED holders using an EDM machine.
    It occurs to me that a conventional carbon electrode EDM would work well, making a 9mm diameter electrode to simulate the pin one the end of the Multifix strap and then eroding a bit of metal until the fit is good. It would be great if I could find someone within driving distance of Los Angeles so I could bring all the parts and test-fit after eroding so as to not remove too much metal.
    Also, I need to make a proper hold-down bolt for the Multifix E. At the moment I am using a T-Nut fitting the HLV-H compound that came with a KDK 100 toolpost, and a 7/16-14 cap screw. This works OK and allows me to use the setup for trepanning (see attached photo). But I would like to make a "proper" hold-down.
    My questions are:
    1. Is a bolt coming from below with a nut on top of the toolpost superior for any reason other than eliminating the possibility of the bolt driving through the T-nut to the compound? The T-nut I'm using on the HLV-H has an incomplete thread to prevent this
    2. Is there any relationship between toolpost size and the size of the T-nut where it contacts the T-slot in the compound? In other words, how big should the contact are of the T-nut be to distribute the clamping force evenly and be sufficient for the size of the toolpost?
    Thanks in advance!
  5. #25
    Apr 2005
    Maine
    345
    26
    21
    Posted in the General section about my questions regarding T-bolts for the compound T-slot and have got a lot of good replies:
    Best Way to Make T-Slot Bolts for Lathe Compound / QC Toolpost
  6. #26
    Feb 2010
    ch
    2,585
    220
    341
    just so everybody knows: the "original" multifix made in switzerland has not been produced for decades.
  7. Likes cinematechnic liked this post
  8. #27
    Feb 2003
    Athens GA USA
    202
    28
    14
    Dian,
    Nice to read your linked thread on Multifix. However the photos and linked photos are missing. Is there any chance you could re-post them? It would be really nice to see them.
    Many thanks!
  9. #28
    Feb 2010
    ch
    2,585
    220
    341
    i think you need to download an "photobucket embed fix" for your bouser(s). i see them just fine.
  10. #29
    Feb 2003
    Athens GA USA
    202
    28
    14
    @dian Ahh, thank you...that solved the problem.
  11. #30
    Apr 2005
    Maine
    345
    26
    21
    Quote Originally Posted by steve-l View Post
    ...In case you are a Multi-fix user, be aware that there is a new style cut-off tool holder from China that is greatly superior to the original Swiss style...
    I'm quite interested to know how the Chinese cut-off holders are better than the original Swiss design. I have switch to Multifix and need to get a cut-off holder.
    I've got two Multifix setups now, size -A- and -E-. The A was made by J.F. Minder and the E by Mivesa.
    Quote Originally Posted by dian View Post
    Thanks for posting a link to that thread!
  12. #31
    Nov 2009
    37
    14
  13. #32
    Apr 2005
    Maine
    345
    26
    21
    I have an EFI internal threading holder for size E Multifix that I use on my Hardinge HLV-H.
    Even though the Hardinge has a retraction feature on the toolpost slide (which works great for external threads), I prefer using the Multifix EFI's retraction feature for internal threads.
    It is also useful for precision boring since you can prevent the cutting tool from scoring the bore when the carriage is retracted.
  14. #33
    Aug 2016
    NORWAY
    For the record. It is NOT Pee-Wee Tools. Google that, and you end up in the wrong place. The name is Pewetools: Schnellwechselhalter nach Multifix System
    Also, SanTool Werkzeuge in Germany sell both a no-name (probably chinesium) holders, and what I believe are SRW-Amestra German made multifix holders: SanTool Werkzeuge GmbH
    SRW-Amestra:
    UNTERNEHMEN
  15. #34
    Aug 2016
    NORWAY
    SRW-Amestra:
    UNTERNEHMEN
