Maarten (from The Netherlands)
- Sep 28, 2007
- The Netherlands
The Weiler 220 series run with a 600mm long belt with a width of 26mm and thickness of 8mm. De belt angle is 32 degrees.
If you are looking for a new belt you will find that you can't get the right belt angle with the present suppliers.
I found a solution. I privatly ordered a batch of correct belts. The belts have a kevlar thread so you don't have to adjust the drivebelt as often as usual.
To keep the vario drive is better than to convert the machine to a frequenty driven one.
If i can help someone with a belt please contact me.
(i'm still looking for some parts for my Weiler LD220 so if you have some spares please contact me)
