Electrical problem Hembrug AI??
KingKustom
Feb 27, 2013
Purmerend, Netherlands
Hi y’all,
I think I’ve got a small electrical problem on my AI. When I’m turning, the machine sometimes makes a rattle sound and then turns itself off electorally, I then put off the machine with the normal on/off handle.
After I push the red button on the left side of the machine all works good again. I have a red push button and a mainswitch, I push the button to get going again.
Sometimes this happens after a few hours of turning, sometimes after a few minutes.
It also makes a difference if I turn aluminum (light work) or steel(heavier work), it happens sooner with heavier work.
I think this is caused by a relay, is this possible, if yes, which relay could this be and is this still available?
Or is there an alternative solution to this.
If this is an electric problem then...
Like to hear from you, thanks in advance!!
Greetings,
Kees
