gears for lathe weiler condor vs
Josef Rott
Feb 8, 2020
How can I find gears for lathe weiler condor vs.
I'm looking for 2 gears z = 21
And one gear z = 28
Well finding used is probably a very slim chance, so time to either make or modify a standard available gear. Needed 2 gears for my Chinese 18" lathe ,ordered cutters of eBay from China cheap. Made gears !
You can buy standard gears so cheap No need to make them
Modul on the Condor is 1.5
HOWEVER
The Z=21 originaly from Weiler is a special gear as it is bigger as normal That needs to be made on a hobbing machine
The hole in it is so big that you have no more meat for a nut in a standard gear
I happen to have a picture of one made from a stock gear(left) and a original one
attachment.php
You can see the toothprofile is different on the one from Weiler
The left one has very little meat left in the key way
Peter
Probably at Weiler
Another BUT
I know that on a Matador Weiler changed the theading chart and also the gears needed with a Z=25 gear as the smallest one
THE REST OF THE MACHINE STAYED THE SAME
So you can use a new threading chart with Z=25 gear on a machine with a Z=21 gear as the smallest change gear
I have a threading cart for a matador with a Z=25 Not for a Condor
Perhaps someone finds a theading chart with Z=25 on his Condor ???
Peter
Probably at Weiler
Another BUT
Peter
Thanks Peter, you really are an expert
