Hi Don,
I`m just experiencing a problem with a controller board of my BP mill and one member here helped me out immidiately with a very extensive diagramm, descriptions.
Anyway, the despcriptions says: Operating ambient temperature :- +10 degrees C to +35 degrees C.= 50-95 Fahrenheit.
Such a high operating ambient temperature I didn`t expect, despite it`s age of some 30 years.
I used to work on tower and shipyard cranes where temps easily drop below -5F and raising above 120F inside the electrical cabinet. We experienced plenty problems particular in SE-Asia where the temps exceeded some 180F inside the cabinet. But not the contactors gave up but the PLC boards.
I`m still working on my problem with the table feed controller board but one fault I found being three cold solder joints of one coil. I discovered it only cause I could feel a shaking movement when handling the circuit board. I guess it`s showing its age.
I know that the SAG12 is having this speed joystick at the apron and some microswitches which control the electrical magnetic clutches. Wether your problem is with your old electrical/electronical system or with your RPC I cannot say. I know that these clutches may fail and I heard that some owners simply swapped them when the faulty clutch was in a low speedrange because they are horribly expensive to buy. However without knowing the full story and being anything but an expert I`d look at the plan what`s happening when the RPC and the lathes` system is drawing full current. I don`t envy you.
Rainer
