Hello All
I am new to this site and a recent Graziano SAG 12S owner. I am also searching for a copy of the 12S manual and thought that I would bump this thread up. To date I have been able to use the older SAG12 manual to figure some of the mechanical areas of the lathe but there are significant differences in many areas. Was anyone able to track down a SAG12S manual? So far I have contacted Tony from lathes.co.uk and Ugo Montagno, a parts dealer in Italy without luck.
Also, I have attached a photo of what I think is an extension to the spindle on my lathe. Does anyone know if this is a stock piece? The bore of this is 1.375" whereas the bore through the rest of the spindle is 1.625" You can see the step inside the bore in one photo. This "extension" has spanner holes (one well worn) and a set screw which makes it look like it comes off...but it doesn't move! Lastly, does anyone know what the sensor above the spindle is doing? It is above a gear that doesn't engage anything. I need a manual!
Thanks for your help and I will share anything that is learned.
Aaron S.
