Graziano SAG 17 lathe, $.82 a LB, delivered - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21
    Jun 2016
    New York
    1,496
    817
    644
    No, actually, to do that I loosen the retainer "plates" on either side of the compound riser block. thats the four socket head caps crews that you see just below the slot in the photo (actually to the left of the slot, the pic is sideways).
    the slot has nothing to do with adjusting the compound, so what does go in there? I was thinking it’s a good spot for the DRO scale, but don’t want to block it if there is some other useful function to it. Thanks for info in advance, cheers!
  2. #22
    Dec 2010
    Sydney Au
    429
    47
    46
    A long time ago, I'm pretty sure there was some mention of the slot on here....must have been pretty inconsequential....and never seen anything sitting in it, with the various grazianos in use or being sold over here.
    I'd make sure I have a good tailstock stop, when you install the dro, if using glass scales though.
  3. Likes cyanidekid liked this post
  4. #23
    Jun 2006
    Thunder Bay Canada
    1,807
    565
    304
    Perhaps it was intended as a coolant drain channel.
  5. #24
    Jun 2016
    New York
    1,496
    817
    644
    If it was just a coolant drain channel I seriously doubt it would have the dovetail. Something went in there. Sure someone knows, Cross slide stop?
  6. #25
    May 2002
    Auckland, New Zealand
    4,442
    1589
    450
    Quote Originally Posted by cyanidekid View Post
    I put a 18" piece of 1" shafting in the chuck, indicator right by the chuck, and pushed/pulled on the end of it with 50 lbs or so of force. chuck seems tight on the spindle, doubt I'm bending the rod much.
    It might simply be the chuck jaws are bell mouthed, so allowing the shaft to bend and move.
    I doubt the chuck is loose or the spindle needs any attention. In fact I would strongly advise leaving the spindle bearings alone!
  7. #26
    Jun 2006
    Thunder Bay Canada
    1,807
    565
    304
    Could be. The long/cross feed lever is spring loaded to pop out of engagement when a certain resistance is felt.
  8. Likes cyanidekid liked this post
  9. #27
    May 2002
    4,442
    1589
    450
    Here are the change gears supplied with a Sag 14, according to the factory list of accessories:
    20, 26, 29, 30, 31, 45, 47, 52, 58, 60, 64.
    Not including the gears fitted to lathe: 20, 40, 80.
  10. Likes cyanidekid, triumph406, BillE liked this post
  11. #28
    Jun 2016
    New York
    1,496
    817
    644
    Dropped the apron last night, it's about as good as you could expect in there.
    a bit rough on the outside, but nice inside
  12. Likes Peter S, BillE liked this post
  13. #29
    Dec 2015
    Connecticut
    820
    22
    246
    Looks nice and clean!
    Sent from my iPad using Tapatalk Pro
  14. Likes cyanidekid liked this post
  15. #30
    Jun 2016
    New York
    1,496
    817
    644
    yes, clean inside, but here is the reason I dropped it,
  16. #31
    Jun 2009
    Rosamond, CA
    386
    105
    289
    What goes in the dovetail slot on the right side of the saddle?
    I have the same slot on my SAG 12; never figured out what it's for. Follow Rest?
  17. #32
    Mar 2009
    4,972
    89
    910
    Visited somebody to help them with getting their SAG to work, after he took it apart and didn't put it back together 100%.
    After I fixed his problem the lathe was working good. He told me that removing the gear box was a mistake. He had a hell of
    a time to install it correctly, lining up gears. He said that when the tray is being pushed back in you can't see what you
    are trying to line up. So there are a lot of trial and error sessions.
    I really like those machines. So did this guy. He had three others in parts that he was going to build and keep or sell.
  18. Likes BillE liked this post
  19. #33
    Langley, B.C.
    1,661
    335
    970
    A little off topic but......we had a SAG 14 for several years. Came out of a shop in Ontario and had severe wear
    on the first 18" or so of the bed. After some serious discussion with the seller (a dealer) we agreed to split the
    cost of having the bed ground. Cost us about $2500 (half of the total) in the late 80s but it was worth every penny.
    You could make an 18" pass on a part and not see anything more than tenths of runout. We down-sized in '98 and
    sold the lathe which was one of the dumbest things we've ever done.
    But I have a question about change gears. In all the years we had the lathe I don't remember having to change any
    gears when cutting threads--I know we didn't have any spare gears with the machine. Were the change gears only
    for module or diametrical threads? Or perhaps metric? I know we didn't cut many of those back in the 80s...
  20. #34
    Dec 2010
    Sydney Au
    429
    47
    46
    Quote Originally Posted by 310 Guy View Post
    Travelling steady will bolt to the front of the saddle.
    Quote Originally Posted by rons
    He had a hell of
    It's a fun game! Repressed memory but I think I used contact cement on the selector forks to hold things in place....along with careful measurement of gear position. Front cover is bloody heavy, expect a 17 isn't much different, a hydraulic table - and level floor - for positioning will no doubt come in handy if the need arises.
    Quote Originally Posted by LKeithR
    Can't remember the last time I cut a thread on a manual! At least for most common threads, standard gears and the feed gearbox should deliver what you need.
  21. #35
    Jun 2016
    New York
    1,496
    817
    644
    I'm pretty sure the follow rest goes on the left side of the saddle, there are two slots milled in it there. the dovetail on the right side is too tiny for a traveling steady. there is a spot on the cross slide for something that looks like it would interact with a stop in the dovetail, so I'm convinced its for a cross slide stop
    as to the change gears, yup, you need them for modular and diametrical, and for threads not on the standard chart, like 48 or M .45
  22. #36
    Jun 2006
    Thunder Bay Canada
    1,807
    565
    304
    Maybe the slot is for a milling attachment?
  23. #37
    Jun 2016
    New York
    1,496
    817
    644
    got into the apron and the screw and rods have some clean parts to reassemble!
  24. Likes e-fishin-c liked this post
  25. #38
    Jun 2016
    New York
    1,496
    817
    644
    I’ve been remiss in posting progress on this, but it is back together, I’ve been busy with other work, still meet to run a 30a line for it, but it’s looking better!
  26. Likes BillE liked this post
  27. #39
    Jan 2011
    114
    90
    27
    I had a similar problem lining up the gear forks. Had to go in there as the 4,8,16,32 gear would not engage. Probably the most used range for
    us North Americans... eventually found that the taper dowel on the select lever was missing and was not timed by just a tad as the other ranges
    worked. After finding that and proving the fork/ gear alignment like you, I took several tries to seat the invisible forks to the invisible gears.
    This SAG folks were smart as they mounted the forks on longer than needed sliding dowels. Pull all of them out to a reasonable extent and now
    you can see to steer the forks to the gears. After I discovered that I was no longer cursing and having a pity party.
    Chuck
  28. Likes Peter S, BillE liked this post
  29. #40
    Jun 2016
    New York
    1,496
    817
    644
    haven't used the Graz much since doing the cleanup, but since I've gotten on it, well.. I realized I've underestimated the Italian beauty once again! the dial on the cross slide is graduated in diameter, not actual motion, so the backlash is actually about .003, nice!
