Graziano Sag12 24vdc clutches.
catch22
Sep 23, 2006
CANADA
I'm thinking about using a 24 volt dc power supply to run the clutches. Does anyone know how many amps that the 24 vdc power supply would need to be.
Thanks Mike
The sparky here went by basic electrical formula of power and voltage to arrive at the current. I'm not sure if the 12 has the same 46W coil, it should be straightforward to derive if the clutch is outside the box to inspect. The transformer here wasn't exactly right either I recall - must see if I can find it after all this time to jog memory.
