Graziano tortona sag 210 question
Likes Likes:  0
Results 1 to 3 of 3
    Dec 2012
    Australia
    Default Graziano tortona sag 210 question
    Hi
    Can anybody help? We're having trouble starting up our lathe. It powers up, but won't allow speed selection. Sometimes, the chuck suddenly turns, but then stops. I suspect a sticky contact problem, or a problem with the circuit breaker connected to the chuck. Could cold weather have an effect on this problem.
    Many thanks for any input.
    Dec 2010
    Sydney Au
    434
    50
    47
    Usual problem is motor turns over, but the pressure switch on the gearbox doesn't see a good enough oil pressure signal to maintain the running state - which I think might be affected by cold weather viscosity.....the one here wouldn't maintain running condition the other week. Haven't experienced a situation where the motor runs and speed selection causes it to stop. Only other problem here has been a sticky main contactor and that resulted in no start of the motor at all.
    There's a few differences between the versions and the various hp varieties over the years. Do have some bits and pieces of diagram that have been drawn up for this mid 70s bastardised IMC version, with conversion to PLC control.
    Dec 2012
    Australia
    Quote Originally Posted by BillE View Post
    Many thanks for this, BillE. I have passed it on to the Machinist. Appreciate your help!
