How to repair Ramco Chinese lathe carriage - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Mar 2019
    18
    5
    Quote Originally Posted by Richard King View Post
    What part of CA are you from? If your in the Bay Area, I have several friends who if they are in the area would help. It's very simple to take apart. Did you buy a manual for the machine? There are several of us willing and able to help you. Put the ones who tease you on ignore.
    Southern Ca but I can always facetime my problem
  2. #22
    Mar 2019
    18
    5
    Quote Originally Posted by ripperj View Post
    What’s the bottom rod? Auto Feed trip?
    Looks like you pop off the 4 shafts and drop the apron- are there 4 Allen bolts on the front top side of the saddle?
    Before you go too far, what’s the issue?
    yes the bottom rod is a Feed trip and it does have the 4 cap screws that holds it to the top plate.
  3. #23
    Dec 2015
    Connecticut
    837
    22
    248
    The shafts have a coupling with a taper pin at the headstock end, easy to get to
  4. #24
    Dec 2015
    Connecticut
    837
    22
    248
    Not sure what size lathe you have, mines a 16” (24 gap) and the apron is really heavy. Remove two cap screws diagonally from each other and put a piece of threaded rod in the missing bolt holes, put a washer and nut on the rod and snug it up, then remove the other two cap screws and lower the apron with the nuts.
  5. Likes skipjackbill, rpseguin liked this post
  6. #25
    Mar 2016
    61
    28
    Where in southern socal?
    If I'm close I'll stop by and help.
