Köping S8 - 1948 Vintage - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Oct 2009
    UK
    220
    292
    115
    Lovely looking lathes !.
  2. #22
    Jun 2014
    6
    Quote Originally Posted by Bvetvik View Post
    Regarding the way oilers..
    I just bought some 1" wool felt polishing wheels of ebay. Paid 15$ including shipping.
    3" 80mm x1" 25mm Thicks 3 Pieces of Polishing and Finishing Wool Felt Wheel | eBay
    Nice!
    I'm thinking of a way to make the rubber way scrapers. They charge 300$ for them at Storebro Service....
  3. #23
    Nov 2011
    NORWAY
    14
    5
    Hmmm.. I don't think I need to replace mine actually.
    But wouldn't this be simple enough to make out of rubber sheet of approximately correct thickness?
    Using a Vee-block or similar to act as a template?
  4. #24
    Feb 2013
    midlands,UK
    3,153
    1626
    1541
    Quote Originally Posted by Stefan_Berglund View Post
    Nice!
    If some bits of rubber are $300 ,how on earth much would something like a headstock gear be?
  5. Likes Bvetvik liked this post
  6. #25
    Jun 2014
    6
    About 1000$..
  7. #26
    Feb 2013
    midlands,UK
    3,153
    1626
    1541
    About 1000$..
    That seems quite reasonable in comparison.
  8. #27
    Mar 2012
    The Netherlands
    153
    104
    32
    Nice lathe! Never seen one over here (only 1000 km from Sweden..)
    Maybe it is an option to make the wipers with abrasive waterjet cutting? Last week I made some rubber washers to mount a machine on with the AWJ at work, worked good, nice surface quality of the cut.
  9. Likes Bvetvik liked this post
  10. #28
    Nov 2011
    NORWAY
    14
    5
    So, to get the thread back on track
    I finally got the jib crane welded up and trail mounted this weekend. Everything fit as planned, so the next step will be painting (oh the horror)... Will probable take som time before that happens..
    Last night I re-mounted the motor, and today I bought new electrical parts (push buttons, contactor and so on).
    Hopefully I will be able to make the first test run this weekend..
    After the electrical work is done, the lathe can finally be moved in to its new spot (if only it fits through the door. That will be a tight fit)
    Pictures to come...
  11. #29
    Nov 2011
    NORWAY
    14
    5
    So, this Friday I finally got the electrical work stated, and almost finnished..
    Wired up the new control panel, with start, stop an emergency stop.
    Also wired up the contactor and fuses for the control panel..
    Last is a picture of the new jib crane mounted in place..
  12. #30
    May 2020
    PORTUGAL
    Hi
    i have the same lathe , but I have some doubts how to remove the back plate
    Shared album - dani47 - Google Photos
    I already loosened a lock nut in the direction ( the image) and in which direction I unscrew the backplate?
    thanks
