LANCE/ZUBAL lathe lube info wanted?
Results 1 to 5 of 5
    Oct 2016
    CANADA
    British Columbia
    46
    11
    Default LANCE/ZUBAL lathe lube info wanted?
    Hi all.
    We have a Lance lathe-made in Spain, where I work.
    It looks like the model is called Zubal.
    It's in very nice shape for its age. Had a very
    easy life.
    I just noticed that the headstock oil is very low.
    I've been looking at a very dark shadow on the sight glass
    for some time.
    The last time I had the headstock cover off, the oil was abit on the low side. But oil seemed to be getting splashed in all the right places.
    One thing I do remember though is that the oil seemed to be ATF oil
    \and reddish in colour.
    I think its time to drain out the old oil give it a bit of a clean
    and start with some fresh oil. Onyone know what oil is recommended
    for this lathe? We don't have the manual.
    May 2002
    Auckland, New Zealand
    4,657
    2506
    664
    If you search Google with 'zubal lathe' there are quite a few hits, e.g. in images I found these two pdf's:
    These two are on the MDNA website (Machinery Dealers National Association):
    Operators manual for C 750 & C 100. https://www.mdna.org/images/File/files/22286.pdf
    Brochure for Model C lathes: https://www.mdna.org/images/File/files/22162.pdf
  3. Likes cyanidekid liked this post
    Oct 2016
    CANADA
    British Columbia
    46
    11
    Peter thanks for the extra info.
    None of the pdf's have any info on oil/grease type recommendations.
    May 2002
    4,657
    2506
    664
    Wally318,
    Page 14 has a little info, it says to use "Campsa A5 or A7 or C4 or C7".
    Campsa was the Spanish state oil company, now mostly part of Repsol (Wikipedia).
    Perhaps you could ask your favourite oil company's technical advisors for a cross reference for these specifications, also mention the era the lathe was made.
    Please note, page 14 mentions "greasing spots" but this surely refers to the grease-type fittings, not the lubricant. Use oil only. I am not certain about the headstock reference to greasing though.
    Actually, it is no big deal getting oil for your lathe, you don't really need to know the original specs in my opinion. You can get modern slideway oil for the ways (ISO 68 viscosity I think?) I use Shell Tonna 68 but I think Mobil Vactra No.2 is similar?? Please check the Mobil reference, others here know more about this.
    For the other parts, I think hydraulic oil will do e.g. ISO grade 46. My lathe (1960's) uses Shell Tellus 46 or Mobil DTE Oil Medium for the headstock, feed box and apron.
    There are others on the forum who know more about oils, maybe ask a lube question in the "General" section of the forum.
    Edit: I re-read your post and see it is specifically asking about headstock oil, so apologies for the other waffle I have posted. For some reason I thought it was just a manual you wanted. Not enough sleep is my excuse
    Oct 2016
    CANADA
    British Columbia
    46
    11
    Peter, thanks for the input.
    Sorry I didn't get back sooner.
    I did the oil change on Thurs.
    Re: way oil-agreed way oil and oil for ball oil
    ports is fairly basic, can be done with whatever are
    current standards. Headstock can be a bit more specific.
    But some generic standards can still apply.
    A high speed spindle on a CNC mill will need thinner oil
    to deal with 12,000 rpm.
    A lathe spindle with 1500 rpm can/should be a bit thicker.
    My colchester chipmaster with a 3000 rpm top speed and
    Gamet bearings calls for something a bit thinner ISO 15 oil.
    Your recommend of ISO 46 oil seemed reasonable.
    On the home machinist forum I got similar answers
    as well as Mobile DTE med and light.
    After a bit of reading I decided to go with Tellus 32,
    we had that in the shop. Well suited to the job at hand
    not too thin, not too thick. Thanks.
  7. Likes Peter S liked this post
