Colchester chipmaster questions
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2016
    CANADA
    British Columbia
    26
    6
    Default Colchester chipmaster questions
    Hello. Is this the right place to post re:Colchester lathes?
    I'm just getting ready to move a Chipmaster into my shop.
    In the manual it says to never use the lead/feed screw reversing
    lever with the machine is running. I've seen a youtube video of
    an owner instantly reversing the feed with the lever while running.
    Any insight on that?
    Secondly, there is a machined flat running the length of the back
    of the bed casting. I know this was to mount a tracing attachment(parts)
    Was it used for any other application?
    Jun 2006
    Thunder Bay Canada
    1,824
    573
    308
    While I'm not familiar with your Colchester lathe,I know that the acceptability of reversing the feedbox while it is rotating is largely dependent on its rpm which of course is related to spindle rpm and feed setting (fine vs coarse). If you hear gears grinding don't do it!
    Standard Modern 1660 lathes reversed the feedbox with a lever for threading. However, above a certain rpm the drive key would shear from the resulting jolt.
    Maybe post a video link so that we can see how this guy reversed the feedbox.
    Sep 2008
    Canada
    1,013
    408
    390
    You run the risk off stripping a gear or the feedbelt. So easy to just stop and reverse and re- start...
    The taper attachment is independent of the machined back on the bed. Don't know of anything other than the tracing attachment using it.
    Btw- congrats on getting a Chippie- underrated lathe imho.
    L7
    Dec 2012
    AUSTRALIA
    2,409
    10
    755
    ...The Chipmaster is a very nice machine ,and far more rigid than the Student or Bantam models that it resembles.The whole feed gearbox mechanism is the same as the Bantam ,and these boxes were so often broken by students ,spares are impossible to find new or used.......edit ...only on some models,others are unique to the Chippie.
