kilohertz
- Aug 11, 2018
- Slightly left of Vernon, BC
HI all,
As you may have seen in my other post, Lathesaurus Rex, I have acquired a Voest DATR-1.5 lathe and have it all cleaned, lubed and operating, but as this is my first lathe, and the service manual I have doesn't explain the operation well enough for me to figure out how to correctly operate this. My main concern is changing the longitudinal feed rate, I can't seem to slow it down enough to get a fine cut. Operating at a spindle speed of 975RPM, turning 1.25" aluminum. I have changed the star wheel from 1 to 11 and it still seems to be feeding too fast. Lever A is in position II. The external gears under the gear cover on the headstock are from top to bottom, 33, 57 and 66.
Any help, greatly appreciated. Is there an operators manual out there somewhere?
Cheers
Cheers
