fultorn
- Apr 17, 2014
- Montgomery, AL
have a bad ball nut and ball screw on our mori seiki SL25,
and i got all the covers off and i can see where the motor and the upper thrust bearings and where the Ball nut would un-bolt from the cross slide.
but i can figure out how to get to the thrust bearing block at the bottom with the 3 angular contact bearings and the nut at the end of the ball screw.
there is a large block that is inbetween the ways that looks like it could be removed to access it. but cant seem to figure out how to remove it.
here are some pictures
