My Caz 360 got delivered a few days ago so I thought I might share some pictures if anyone is interested. Goes without saying that this machine is extremely dirty and covered with years of dried on oil, dirt and other various grime, it's going to take me a long time to clean it up.
Caz 360 - 1 pictures by pastypies - Photobucket
As with so many of these machines the bottom hydraulic actuator is leaking all over the place and possibly also the top one as well. Also looks like I'm going to need to take the apron and lead screw off as there is considerable play in the longitudinal dial to the left of the main longitudinal hand wheel, I'm hoping it's just in need of a new bearing and not something more sinister.
As you can see my machine has come factory fitted with a hydraulic copy unit, I think it is all there and in working order but until I can get the machine up and running I won't know for sure.
I'm stuck on single phase in my workshop so I will be running this machine via a 7.5Kw VFD. Assuming I can fix the leaking hydraulics I intend to integrate the existing switching and brake to the VFD, watch this space.
Has anyone actually removed the apron and lead screw assembly and if so where do you start?
Might also need some help on removing the hydraulic actuators top and bottom, in fact I can't even tell how to remove the bottom unit as there are no visible bolts or screws, any help or advice would be most welcome.
http://i43.photobucket.com/albums/e387/pastypies/Caz%20360%20-%201/DSC00392.jpg
I understand I will need to purchase a slide hammer to remove the actuators so I will get one in the week.
I had a Harrison 155 before this machine which was the metric version of the L6, not a bad machine but the Caz is far more complex, assuming I can fix the glitches with it however it's going to be a lot more productive than my old machine.
Steve...
Steve...
