Need Flat drive belt for Swiss Sixis Machine, 18mm wide x 620mm long, 1.5 thick
Results 1 to 5 of 5
    Jan 2003
    Pacific Northwest
    1,296
    74
    Default Need Flat drive belt for Swiss Sixis Machine, 18mm wide x 620mm long, 1.5 thick
    We are looking for a source for these belts.
    Jan 2003
    Pacific Northwest
    1,296
    74
    We can buy belt a material from Habasit called machine tape MAT-5P. Their joining fee is high and we would like to make it in the shop to adjust the length.
    Has anyone ever bonded this material without the expensive bonding tool?
    Feb 2001
    Redwood City, CA USA
    4,688
    146
    759
    Al Bino or McMaster might have what you need, depending on whether you need a functional belt or an exact match. I used a made-to-order flat belt from McMaster on my old Aciera F2. Monarch might have a source for flat belts, since they are used on the feed drive in 10EE lathes.
    Sep 2005
    Oakland, CA
    2,174
    131
    529
    Will leather work? if so:
    Custom Leather Drive Belts-Single-ply (11/64'&#39, up to 4'' wide
    owned by John Knox- ex head mechanical engineer at Sheldon Machine Tools.
    Mar 2001
    Switzerland
    2,449
    2072
    1016
    Most any supplier of Habasit stuff will join it for you. Had it done when I was based in Cincinnati, then the corner hardware store here in Switzerland (yes hardware stores here can be pretty awesome). A few bucks. Finally grabbed a used Habasit heater so I do them myself now. I'm pretty sure some places rent them for situations where it needs to be joined in place.
    Edit- I see you're looking at a different product than the usual Habasit green-yellow machine belting. The regular stuff gets scarfed glued then put in a clamp heater. I might have some 18mm around here...
