Schaublin 102N - Why the extended spindle ? (photos)
Results 1 to 5 of 5
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,291
    2787
    5609
    Default Schaublin 102N - Why the extended spindle ? (photos)
    Bought the below recently. Any idea what the extended spindle tube is all about ? Maybe it had a pneumatic closer at one time ?
    Jan 2005
    The Netherlands
    5,724
    263
    1442
    Its voor placing the lever operated draw bar
    Peter
    Virginia
    26,767
    7561
    8375
    Quote Originally Posted by Milacron View Post
    What Peter said.
    Plus - as with the French HBX-360-BC you sold me - any lathe that uses separate extensions can readily support swapping for other extension options without disturbing the spindle, proper.
    I'd rate that approach as "a feature, not a bug", and one that adds value.
    Jun 2006
    San Jose, CA
    582
    496
    55
    Nice looking lathe!!
    My rusty Graziano Sag 12S project has a similar tube at the end and I’m thinking it’s probably for a collet closer.
    Virginia
    26,767
    7561
    8375
    Quote Originally Posted by rpseguin View Post
    ..similar tube at the end and I’m thinking it’s probably for a collet closer.
    Well "not only". All of my collet systems are nose-actuated in one way or another. I don't think I've even seen a manual rear-closer fitted to a Cazeneuve. Powered is another story.
    But many of the "modern" squared-off lathes - the HBX-360 among them as well as the Graziano and this particular family of Schaublin - need an extension tube simply so one can find the spindle bore to feed a rod or bar of stock into without having to take the end cover(s) off. The extension also limits whip, protecting other goodies in the area, though a supplementary support may still be needed when stock is long.
    The "working" spindle itself otherwise ends somewhere deep inside.
  6. Likes rpseguin liked this post
