Schaublin 13 1954
offir sherman
Nov 10, 2020
Hi,
I am new member.
I have Schaublin 13 milling machine 1954. I am looking for Plans or Manual operation 1953 or before 1955. I have the full Manual operation with plans from 1956-1969 but there are some slight changes one of which is with worm gear. 1954 is different from 1956 on. I also have the 1953 MO which is fine but with only three plans so I need some more...
I am trying to figure out what the exact parts that should be on the worm gear? The plan attached is from 1956 production it not good for me I need earlier version.
If anyone recognise this worm gear in the pic attached, and has the exact worm gear and know what bearing should be on it or has its own pic it will help.
According to page 10 of MO 1956 the bearing should be SKF 6002X with internal diameter 15mm, but the worm gear I have has 22.4mm so bearing 6002X is no good.
Do you think I should fit the worm gear to the size of the bearing 6002X i.e. from 22.4mm to 15mm if I do not find the exact bearing?
Your help is highly appreciated
offir
[email protected]
