Schaublin 150 Missing A Steady Rest, Trying To Find A Suitable Replacement
Likes Likes:  0
Results 1 to 10 of 10
    Feb 2014
    Toronto Canada
    190
    34
    Default Schaublin 150 Missing A Steady Rest, Trying To Find A Suitable Replacement
    Hi everyone. I have given up trying to find a Schaublin 150 steady rest for my lathe. Should I look for a rest from an appropriate donor lathe or are there other options?
    Feb 2001
    Redwood City, CA USA
    5,347
    252
    1208
    It's fairly easy to take a steady meant for another lathe and change the base to fit your ways. It's also fairly easy to roll your own as a weldment. You could get one of these Metal Lathe Accessories kits and add a base. I did the latter for my Colchester Chipmaster.
    Virginia
    21,047
    7561
    12307
    Quote Originally Posted by Degull View Post
    Cheapest and least effort option is to do without forever. You did say "given up?"
    I think that was the only one left that rklopp hasn't already covered?
    May we go for a beverage, now?
    Sep 2008
    Canada
    1,720
    673
    686
    I assume you phoned the place in Quebec or had a good look see?
    L7
    Feb 2014
    Toronto Canada
    190
    34
    Quote Originally Posted by lucky7 View Post
    L7
    I picked up the lathe from the auction distrubtion center. There was nothing else and no one to contact.
    Feb 2014
    Toronto Canada
    190
    34
    I suppose that I can live without one but I liked using one on my previous lathe.
    Feb 2014
    Toronto Canada
    190
    34
    Quote Originally Posted by rklopp View Post
    Thanks for the suggestion, I think that I will try to find a suitable match and adapt it to work.
    May 2005
    Interior British Columbia
    2,812
    328
    945
    I posted a link to a lathe manual over in this thread E3N-01 Kart lathe change gears
    If you open the PDF and scroll down through the pictures therein, they show some pretty nice profiles for their Steady and Follow Rests, that would be dead easy to scale up or down as needed, and used as a reference for either building your own Steady or perhaps as a full size drawing to use for a comparison so as to see if your 'possible' is going to work well or not.
    Just sayin'.
    Cheers
    Feb 2014
    Toronto Canada
    190
    34
    Quote Originally Posted by trevj View Post
    Just sayin'.
    Cheers
    That helps a lot, I plan to search for a worthy donor. I have some great drawings of the 150 steady rest and bed ways cross section that should make it a simple. The best path is more clear now. Thank you!
    Dec 2004
    MA
    130
    30
    41
