firststrike
- Jun 22, 2012
- wales, ystradgynlais
Firstly hello to all, we have a schaublin 13 ( manufactured 1964). I am trying to use the horizontal arbour attachment which currently has a 1.6mm saw blade type cutter fitted. I want to fit a 25mm convex cutter onto the arbour but cannot dismantle it, one end has the number 4 morse taper fits into the milling machine the other end has a spacer with 2 flats on. Spent the afternoon trying to remove the spacer with 2 flats ( "nut") to no avail, is it a normal r/h thread or is it l/h thread? Also is there a way to lock the drive shaft on the schaublin 13? Any help much appreciated.
