Webb/Whacheon WL-435 Lathe - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 76 of 76
  1. #61
    Jun 2006
    841
    774
    101
    Now I have to get my brake installed and working.
    It was just laying on the bottom of the motor cabinet, not mounted:
    Iím assuming this is the reservoir and cylinder near the brake pedal:
    Just standard brake fluid?
  2. #62
    Jun 2006
    841
    774
    101
    Looks like something is wrong with the brake pedal cylinder or the line.
    I put in brake fluid and pumped the pedal a bunch of times, but nothing came out at the end of the line.
    Iíll pull it off and give it a closer look later.
  3. #63
    Jun 2006
    841
    774
    101
    Quote Originally Posted by ripperj View Post
    I have a Namseon which is a Korean quality knock off also, not as polished as your machine, but accurate and nice to run.
    What kind of toolpost setup are you running?
    Mine came with the Mori Seiki style square toolpost, but I want to put on an Aloris type.
    I have been thinking of removing the compound and replacing it with a solid mount, similar to Robin Renzettiís nicely done setup.
    YouTube
  4. #64
    Dec 2015
    Connecticut
    1,171
    27
    388
    I went with Multifix size B. Create Tool version.
    The B size is perfect for my 16Ē lathe
    Nicely made and seems high quality.
    They will make to order the internal and external rapid retract thread tools
  5. #65
    Jun 2006
    841
    774
    101
    The B size is perfect for my 16” lathe
    Nice! I like those multifix toolposts. I've used them a few times and they are nice to use!
    If I were to remove my compound, I could put a CA or DA sized toolpost on. Problem with that is that the CA and DA holders seem generally much more expensive.
    Ooooooh! Nice scraping on the cross slide way!!
    I don't know if my machine ever had anything like that, but if it did, it is long gone! :-)
    I should stop buying basketcase machines and wasting so much time fixing them and instead look for a good deals on fully functional and good condition machines.
    My basket case machines TODO list:
    -install new carriage pinion gear on Webb lathe (lots of work and time)
    -fix brake on the Webb lathe
    -look at belt wobble on my Hardinge in the spindle Reeves drive/pulley assembly. I'm hoping this is an easy fix, as pulling and replacing the spindle drive belt also looks like a pain in the butt!
    -pull carousel ATC off the VMC to fix an air leak in the cylinder (lots of time and effort)
    -track down and fix all the air leaks on my Spinner lathe
    -install way covers on lathes and mill
    -build/find/install backsplash/rear chip pan for Webb lathe
    I buy "cheap" stuff because that's what I can afford up front and I think I can fix them and save money, but I don't see the overall cost of all the time/money/effort I put in.
  6. #66
    May 2008
    Long Beach, CA.
    250
    20
    12
    Quote Originally Posted by rpseguin View Post
    I'm joining you on the buy cheap and hope it all works out in the end lol. I just agreed to buy this Webb badged Whacheon. Hoping it cleans up nicely. If you have scanned your manual or have any other pdfs I would love a copy! Im going to have to make new tags cause they are all about useless.
    Jeff in long beach
  7. Likes rpseguin liked this post
  8. #67
    May 2009
    New Jersey
    264
    54
    42
    Quote Originally Posted by zamboni2354 View Post
    Jeff in long beach
    They're great lathes, very stout...I really like mine (Webb/rebadged Whacheon) and I too have bought my share of cheap/affordable machines. As a hobbyist, I could not afford to do anything different.
  9. Likes zamboni2354, rpseguin liked this post
  10. #68
    May 2008
    Long Beach, CA.
    250
    20
    12
    Quote Originally Posted by jbacc View Post
    Same. I get mine tomorrow. Them the work begins. If you have any manuals, diagrams, etc. Shoot me a message. Thanks.
    Jeff
    Sent from my LM-V405 using Tapatalk
  11. Likes rpseguin liked this post
  12. #69
    Feb 2010
    cleveland
    314
    8
    85
    Itís not that bad of a job, I recently got a Mori MS850 and I took off the top slide to clean and found that the apron was full of muck. So a completed tear down was in order. Coolant got in and it was nasty. Everything was in good shape and the only problem in the apron was the oil pump check valve broke. I can go into detail later if you want. Unfortunately I have some broken gears in the headstock that need addressed. Only have 6 usable speeds. I complained to the auction company and told them I know it wasnít there fault and if the owner had a conscience he would have had them list it as inoperable or needs repair. Well you know what their answer was, too bad.
  13. Likes rpseguin liked this post
  14. #70
    Jun 2006
    841
    774
    101
    Quote Originally Posted by plumberpieco View Post
    Thanks!
    Thatís good to hear!
    Iím going to get to it eventually and Iíd like to do a DRO install too if I can find a good deal on one.
    Unfortunately, my truck started misfiring and needs new heads or a new engine and I donít have the money for that.
    Iím going to sell off a bunch of stuff I donít need to pay for the truck repairs and then save my pennies for a DRO.
    That sucks!!
    Sorry that that happened!
    You should start a thread on your repair of it!
    Iíll definitely be watching that!
    Did you move the carriage all the way down to the tailstock end?
  15. #71
    Feb 2010
    cleveland
    314
    8
    85
    I had supported the apron and removed the top slide with the engine crane while pretty much centered. I had to do this as I had limited mobility with the Crane and itís surroundings. Then slid it off but re installed it differently and would remove the apron with another approach in the future.
    I would first pull the feed and lead screw rods then attach straps to the apron and hang from the crane. Remove the bolts and whatever guide plates and slide the top slide out of the way. Then move the apron with the crane. Thatís how I re assembled it. You could probably slide the whole assembly off the end then disassemble but I chose to piece it off as I was working by myself. You will have to map things out a bit since there is a full base or maybe get the lathe on substantial blocks so the crane can slide underneath it. I thought maybe a die lift cart with forks would be helpful. When Pulling the lead screw Or the feed shaft, I canít remember which, it may want to take the gear box shaft portion out with it so make sure you have good separation. If it comes out some you will have to take the gear box cover off to re align the gears. Itís best to install long bolts and just slide the cover back in place if that happens.
  16. Likes rpseguin liked this post
  17. #72
    Feb 2010
    cleveland
    314
    8
    85
    This the actual pic from the auction
  18. Likes rpseguin, zamboni2354 liked this post
  19. #73
    Feb 2010
    ch
    2,496
    215
    329
    what is that diamond tool? i have ifanger stuff like that.
  20. #74
    May 2008
    Long Beach, CA.
    250
    20
    12
    Well, mine is home. Now the work will begin.
    Jeff in long beach
  21. #75
    Jul 2015
    Colorado
    94
    549
    74
    It’s not that bad of a job, I recently got a Mori MS850 and I took off the top slide to clean and found that the apron was full of muck. So a completed tear down was in order. Coolant got in and it was nasty. Everything was in good shape and the only problem in the apron was the oil pump check valve broke. I can go into detail later if you want. Unfortunately I have some broken gears in the headstock that need addressed. Only have 6 usable speeds. I complained to the auction company and told them I know it wasn’t there fault and if the owner had a conscience he would have had them list it as inoperable or needs repair. Well you know what their answer was, too bad.
    Yep, me too. I purchased a Darbert (Canadian badged Whacheon) at a Canadian auction, sight unseen. That exact same exact gear is damaged. I knew it was my problem because I didn't fly to Canada to inspect it before I bought it, but I got it at a good price, so I'm not gonna cry too much. Instead, I'm gonna run it on a VFD so it doesn't really matter. However, if you wouldn't mind sharing a thread when you replace that gear, I would be interested...
    Kevin
  22. #76
    Apr 2016
    113
    65
    55
    I’ll pull it off and give it a closer look later.
    not much of an expert on lathes but I do know a bit about hydraulic disk brakes.
    You have a few things to check
    1 - brake lines may have degraded or swollen internally, blocking fluid flow
    2 - you might have a load of air in the lines so all you're doing when you're pumping is compressing the air
    3 - the outlet port on the master cylinder (the one in the 2nd pic I'd guess - where you put the fluid in) could be blocked by gunk.
    First thing I'd do is take off the cap to the reservoir, connect a tube to the bleed screw on the caliper and push some fluid up the line to the reservoir. If you get bubbles and then liquid in teh reservoir = air being flushed out. If you get lots of nasty black stuff in the fluid, most likely crappy lines/ general gunk. Either way, if you can get fluid flowing in reverse, I'd then do a simple bleed from the reservoir to the caliper.
    If you have problems later with it being mushy or the pads not retracting properly, you'll most likely need to replace the lines.
    DOT3 should work just fine.
    hope that helps
