Weiler LZ 330 Thread dial
Results 1 to 9 of 9
    Jan 2016
    NORWAY
    15
    Default Weiler LZ 330 Thread dial
    Hi there.
    I have plans to make my own thread dial indicator as I cant source any items for sale.
    However I have struggled to figure out how many teeth it would be sensible to have on the gear..
    Does someone have such a gear and can measure it for me? Or at least the number of teeth?
    Any tips woudl be very velcome.
    with best regards
    Mats Andersen
    Norway
    Dec 2008
    Vt USA
    6,024
    532
    1844
    Mats
    The originally supplied threading dial for the IMPERIAL specification lead screw is a two gear train to provide offset.
    Both gears are identical and carry 16 teeth on a 36 mm outer diameter.
    Jan 2016
    NORWAY
    15
    Quote Originally Posted by CalG View Post
    Mats
    Thanks for the reply. OK thats good to know.
    Allthough I would be working in metric for the most part.. After som further checking it sems metric thread cuttging using dial indicator is a far more complex scene.
    I have not given it too much thought up until now. I have been able to do most of my hobby work for years without turning threads in the lathe.
    I could keep it engaged and run it backwards forwards etc, but the weiler does not have a footbrake so it is tricky to stop the machine going up towards a shoulder for example - which is common scenario.
    A quick retracting toolpost might work but it must be good. ANy tips where to obtain such a device?
    best
    Mats
    Mar 2016
    42
    19
    I can take photos and measurements of my thread dial of it would help
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Jan 2016
    NORWAY
    15
    Quote Originally Posted by readymix View Post
    Oh man that would be awesome! Would you be able to post photos right here?
    Mats
    Jan 2016
    NORWAY
    15
    Thats for metric?
    M
    Mar 2016
    42
    19
    Mine is English so the gear would be different. The rest should be the same
    Jan 2016
    NORWAY
    15
    It seems though as I have found a solution with a retractable tool holder. I can then keep it in gear and reverse, then re apply the cutter.
    Its a shame these machines dont have spindle brake
    M
    Nov 2010
    netherlands
    70
    21
    Mats,
    Did you know that you can open the halfnuts with some threads without a problem.
    When the threadpitch on your leadscrew divided by the thread you want to cut is a whole number, you can do this.
    For example:
    6mm leadscrew 1,5mm thread on the part is
    6/1,5=4
    So you can open the halfnuts here.
    Greetings,
    Peter
    Verzonden vanaf mijn iPhone met Tapatalk
