tjs42
Hot Rolled
- Nov 8, 2003
- portland, oregon
The forward -reverse feed rod shift lever will not engage(either forward of reverse) so there is no power to the carriage. anyone ever have this problem? It looks like there is plate on the face of the gear box through which the feed screw, feed rod and on-off lever control goes that can be taken off and you can then get to the shift lever mechanism. anyone ever have this problem, if so how did you fix it? any help/suggestions are appreciated!! Thanks!! tom
