4140HT steel
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: 4140HT steel
    Mar 2003
    Vermont
    526
    128
    141
    Default 4140HT steel
    Also known as, 4140 PH (pre hardened) HRC 27-32
    My regional distributor historically sold resulfurized, round bar. Great tool life and surface finish. Distributor has switched to a mill suppling product with no free machining additive. Part quality is suffering. Struck out finding the former product elsewhere. Appealing for a domestic source for 4140HT with sulfur or lead additive. Bar size to 12"
    Feb 2005
    9,796
    16796
    11993
    Look for 41L40.
    Jul 2007
    Missoula Mt
    1,442
    62
    709
    No problem in Montana to buy...Phil
    Mar 2016
    1,232
    240
    344
    Bobw's suggestion may be an alternative. In my case, I would prefer turning a harder material. Pre-hardened to 27-32 is useless, finishes improve dramatically if the stock is closer to 36-42 HRC or higher. There is one draw back from using leaded stock; it doesn't black oxide very well.
    Mar 2005
    Kansas
    8,725
    625
    4440
    I used to use a hot rolled 4150 modified that was resulfurized Rc 28-32. Is such a material still available, and would it work for you? At the time I think it came from EMJ.
    Apr 2010
    Wisconsin
    6,219
    4264
    3966
    Quote Originally Posted by 10 fingers View Post
    I always bristle a little when they quote those numbers because I can literally count the number of times that it came in over HRC26 on the hand missing half of one finger.
    It might help to know who your old supplier is in effort to not recommend them. Otherwise, just about everyone has had it for us, lately. I imagine that you and I use it for the same end results. Something I have done in the past when I chose/needed to be anal about the specific heat treat was to buy the less expensive bar stock and harden it myself. You might find that the cost works for you.
    Lastly, the advice that the slightly harder material cuts better definitely correlates to my own experience, but you might want to look at your inserts just the same. I've never had some of the newer grades have any issue at all with the commonly typical range of PreHard. ( and we use it just about every single day )
    Call if you want. Hope you're doing well.
    Mar 2003
    Vermont
    526
    128
    141
    Default Thanks for the feed back.
    Quote Originally Posted by Zahnrad Kopf View Post
    I had resisting elaborating to not complicate the question. Albeit PVD coatings, we are cutting with cobalt HSS not much different than 100 years ago. Material machineability is paramount. Especially with 100s of 12" dia 4 pitch parts. No margin for supplemental heat treat at those weights. Up until a year ago life was great using aforementioned 4140/50HT RS (resulfurized.) Was produced by a mill in France. Unable to find an equivalent material elsewhere.
    Blue skies, -Don
    Apr 2018
    9,177
    4451
    Import it yourself ?
    Jul 2006
    Hillsboro, New Hampshire
    14,118
    3083
    9358
    Quote Originally Posted by EmanuelGoldstein View Post
    Due to Covid, that mill had to retool to churn out baguettes. I did hear they had complaints about the first batches, when they hadn't gotten all the remaining steel out of the mix.
    [Yes, "churning out baguettes" is a terrible mixed-metaphor]
  10. Likes DanielG liked this post
  11. #10
    Oct 2011
    West-Central Illinois, USA
    1,427
    2277
    674
    Making tough gears? LaSalle ETD150 is a 4142 doped with selenium. Elevated temp drawn, quenched & tempered. It WILL test 32Rc (30-34 limits, or call Wilson to get your tester fixed…). Machinability rating 75% of 1212 so plenty good with coated HSS. Find a dist thru Niagra – LaSalle. Or just google "ETD150 steel" and a link should show up.
    2nd choice, Productigear in Chicago buys FX-Xtra from Finkl (same city) for tough ready to machine gear stock. I don’t know which temper but they’re good at getting the hardness (strength) you want. BTW, Finkl is a hot work tools steel house mostly with their own VAR furnaces. Really good stuff...
    Good luck,
    Matt
  12. Likes sfriedberg liked this post
  13. #11
    Mar 2003
    Vermont
    526
    128
    141
    Quote Originally Posted by Matt_Maguire View Post
    Good luck,
    Matt
    I am familiar with ETD 150. Last I knew, was only made up to 3-9/16 dia. http://www.niagaralasalle.com/pdf/etd150casestudies.pdf
  14. #12
    Sep 2006
    Abingdon, VA
    3,795
    5015
    3806
    Gerdau Steel makes some fine 4140/42PHT, see if a distributor can source from them.
    Eaton Steel in Detroit claims to be the "Costco" of steel distributors, and can find or heat treat about anything. If you buy enough tonnage, it could be worth the freight cost.
    Good luck,
    ToolCat
  15. #13
    Aug 2002
    West Unity, Ohio
    27,739
    8080
    9798
    Yeah, I am sure that it is only available into the 3 inches area as it is "drawn".
    Not much actually drawn over 3.5" AFAIK.
    ETD is VERY expensive too.
    I have a bunch on order right now, and the best price that I found was just under $3.
    (waiting for mill run)
    Those that had stock were asking up to $5, and that is the 5000# price too!
    And Amanda @ Eaton told me the other day that she never even heard of that material, so ....
    Think Snow Eh!
    Ox
  16. #14
    Oct 2014
    Maine
    1,347
    268
    644
    Mixed-metaphors are the yeast of your problems. We really knead to stay on-topic.
  17. Likes Ox, Milland, mountie liked this post
  18. #15
    Oct 2011
    1,427
    2277
    674
    OOPs, my bad. Yes the bar and wire mills work with continuous casters & that poop out a 5ish inch bloom then reheat to shove in the mill stands. 300M and 4340 are tougher but I don't know about using HSS unless you have some serious coolant.
    Good luck,
    Matt
  19. #16
    Apr 2018
    9,177
    4451
    Gear machines have serious coolant, no problem there. But some steels cut nicer than others. With carbide you can just jack up the speed to get shiny, but on teeth you don't want shiny so much as clean. Tearing is the biggest problem with shapers.
  20. Likes sfriedberg liked this post
  21. #17
    Jan 2007
    Flushing/Flint, Michigan
    10,893
    640
    8742
    Gear cutting and carbide vs HSS tooling.
    Oh-my over the last 50 decades. Newer carbides better, newer gear machines are faster.
    Older machines and making carbide work economically is not so easy. Dad chased this white whale for quite a while to no success.
    We do have a top notch gear cutting member here whom I think has made it work for him. Other side not talking to me so often so maybe not so good results.
    Bob
  22. #18
    Apr 2018
    9,177
    4451
    We do have a gear cutting member who I think has made it work for him.
    Zahnrad replicated what Pfauter did in the seventies. The problem was not so much "would it work" as "how much $$$ ?" Works for zahn because he does it for himself.
    Have had carbide and carbide-tipped hobs for ages too. Again, the problem is cost, not whether it works. Our gashers used all carbide but the cutters cost $8,000 apiece. Have to make quite a few parts to justify that.
  23. #19
    Mar 2005
    Indiana
    6,401
    2266
    2378
    Good luck,
    Matt
    I'm with you. The 4140 Q&T we bought was always in the middle of spec. Which was 28-32Rc. Generally it tested at 30-32. Never had a problem with finish or tool life, but weren't using HSS for anything but drilling.
    Funny you mention those two, I've done business with both. Productigear makes some good gears, we've had quite a few made there over the years. They aren't cheap though.
    I worked in a shop that made a forging press cylinder for Finkl also. It was a big boy - for a 5,000 ton press. I did some of the lathe work and also the line boring on the HBM (with two other guys, we were 3 shifts there).
    There was a mishap during the lathe work, some idiot had balanced a boring bar (maybe 5' - 6' long) on a single 4x4. One of the guys on another shift stepped on one end to get a step up so he could hook a steel cable to the crane not realizing that the boring bar was precariously balanced in the middle. He lost his balance when that end dropped and that caused the back of his hand to be drawn across the end of the job, which he had not properly chamfered and was near razor sharp. He closed his hand and couldn't reopen it. The sharp edge had cut all the tendons to his fingers in the back of his hand. As you can imagine, he had a very complex surgery and his hand was never the same again. We never did find out who had left the boring bar that way.
  24. #20
    Aug 2002
    West Unity, Ohio
    27,739
    8080
    9798
    I cut one of those same tendons on the little caps that was on a 55 gal drum.
    I decided that I would actually go see someone better qualified at body repairs than myself on that one, as my middle finger dangled.
    (looked like a fag)
    He stitched me up and told me to not doo anything with it for a few weeks.
    I went sledding the next weekend, but I was careful with it, but those are all just "return" muscles/tendons anyhow.
    Not like you are ever going to really overwork those.
    Your guy must have done a lot more than just shear the tendons in two to have that much trouble.
    Only trouble that I have is that my skin seemed to heal fast to the tendon, but it's never an issue anyhow.
    The sun still comes up in the east every day, so I guess all is well.
    Think Snow Eh!
    Ox
