I got a cheap home depot "husky"? brand. I knew it would suck and not last long, but this thing leaks like it is open all the time.
There is a company near me that makes air guns and is very well known. Guardair Corporation is the company. I havent talked to them yet but was hoping someone had personal experience with these before.
I want to know if anyone has experience with high pressure blow guns.
I just purchased a Hardinge GT and want to fix up my air system. I need a refrigerated air dryer and some more water traps. Might as well get some good accessories to go along with it.
I just talked myself out of a screw compressor due to not needing enough air. I guess they like to run a lot and get the oil hot enough to burn off the vapor. That wont happen in my situation, so I am leaning towards adding another tank and keeping a larger supply of air on hand.
The system doesnt leak anywhere except for the nozzles at the end of the line. I think this piston compressor should be fine for a while until I get a few more cnc's.
Any suggestions? Thanks in advance.
