Not everyone has this problem, but I tend to work alone in my garage and every couple months I nearly loose a few fingers.
If you want to know the story read this paragraph, otherwise skip to the solution. The first time was the day after my mini lathe showed up. It is only about 400 lbs and I needed to thread a power cord under it. I picked up the gear head end and was trying to slide a 2x4 under it with my hip, it went to far and I ended up with my fingers between the lathe and the 2x4. I couldn't set it down, but it was too heavy to lift higher and I couldn't hold it with just one hand to use the other. My wife had just left, and my kids were watching TV and wouldn't have a chance of helping anyway. Eventually I did get my hands out by giving it a good jerk upwards and pulling out as fast as possible. A few weeks later I purchased a used forklift to be safer moving heavy items. While adjusting the forks closer together to unload a surface grinder from a trailer, the hydraulics settled a couple inches onto 3 of my fingers. So there I am at about 9:30 at night in the driveway screaming for my wife. We live in a pretty well insulated 2x6 home with 5/8" drywall, she couldn't hear me and after a couple minutes of the forks continuing to settle more and more I was reaching for anything I could with the other hand. Thankfully a neighbor was out on a date roller skating by and heard me yelling and was able to help. I am a hobby dentist, and I have a full office in my basement so I was able to X-ray the fingers to see they were OK, but it was still a bit scary.
OK, so if you read the last paragraph, you can see why you might someday need to scream for help without access to your hands. My wife asked me to figure something out. Maybe you guys already have a great solution, but if not, I stumbled across this project on Kickstarter that seems perfect. It could easily activate a siren, place phone calls and such. I am going to outfit my garage with a couple just in case
ReSpeaker - Add Voice Control Extension To Anything You Like by Seeed —Kickstarter
Alan
Alan
