Assistance with Marking & MIL-STD-130
Results 1 to 11 of 11
    Mar 2015
    24
    Default Assistance with Marking & MIL-STD-130
    Could someone assist me in deciphering what I really need to do, I have never had to do any markings like this.
    Drawing notes:
    Identify per MIL-STD-130 by Stenciling using white lacquer per tt-l-32, type 2.
    This is what I know, or think I know...
    Mark part using Insigna white lacquer, fed-std-595, color 17875.
    Ok, what text am I putting on the part? MIL-STD-130 is so confusing and seems to not anywhere say do this and this.
    Thanks in advance.
    Dec 2014
    New York
    702
    224
    173
    Simplest way is to call your customer and ask.
    Apr 2012
    AR, USA
    824
    17
    141
    Generally,
    ODA-part #
    CDA XXXXX
    MFR YYYYY
    where ODA is the CAGE code of the original design activity (the CAGE on the drawing)
    XXXXX is the CAGE code of the current design activity (only if changed from the ODA)
    YYYYY is your CAGE code
    For example,
    19207-12345678
    CDA 19200
    MFR 12345
    Mar 2015
    24
    Wow, there is no way I can get all that. Area is 2.00 x .250
    Apr 2012
    AR, USA
    824
    17
    141
    1/4" is pretty small. Obviously, you're only going to get one line. I would shorten it until it fit by removing the CDA, then your CAGE, and last the ODA if necessary.
    Mar 2015
    24
    Wow, I have read through it again, and I think I am more confused now.
    Being I am very limited on space, .250 x about 2.00
    Below will not fit
    ODA-part#
    CDA XXXXX
    MFR YYYYY
    Can I eliminate the ODA part?
    CDA XXXXX MFR YYYYY
    Or
    ODA-PIN MFR YYYYY
    Apr 2012
    AR, USA
    824
    17
    141
    The standard does not specify what information is most important, but I would do ODA-PIN MFR YYYYY if there is enough room.
    Apr 2005
    Beaverdam, Virginia
    5,819
    219
    2366
    I haven't done DOD work in ages, I always just marked them with the part number and my cage code. All mine were stamped with 1/8" high characters.
    Oct 2015
    Indiana
    6
    Isn't there a clause in the spec that calls out if the parts are too small to be marked they can be bagged and tagged?
    Apr 2012
    AR, USA
    824
    17
    141
    Quote Originally Posted by dvance85 View Post
    Sure but it sounds like the drawing specifies the method (stenciling with white lacquer), so one couldn't comply with the drawing without marking at least the part number.
  11. #11
    May 2009
    Wyoming
    3,025
    6608
    4672
    CYA.
    Email the customer and explain that since the part is .25 x 2.0 there's obviously not enough room for all the information and you need clear instructions for the marking of the part. Somebody authorized will have to reply with a name and title...probably ruining his day.
