Best Mill for a Makerspace
View Poll Results: Which mill should I get for a makerspace?
Voters
22. This poll is closed
  • Get the Haas Mini Mill EDU
    20 90.91%
  • Get the Tormach 1100MX
    2 9.09%
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
    Feb 2021
    Massachusetts
    13
    Question Best Mill for a Makerspace
    Hi All,
    First time poster, so I apologize/feel free to give me a pointer if I am posting this in the wrong part of the forum.
    I wanted to get some advice on the best milling machine to buy for a makerspace.
    A makerspace is a like a community workshop (more information about what a makerspace is can be found online here What is a Makerspace? Is it a Hackerspace or a Makerspace?).
    I am trying to decide between a Tormach and a Haas. Specifically, I am trying to decide between two machines: the Haas Mini Mill EDU, which is listed at $21,995 (assuming that as a makerspace I can purchase the EDU version) and the Tormach 1100MX which is $22,234.0 with the options needed to make it equivalent to the Haas (so with an enclosure, Automatic Oiler Kit, Door Lock Switch Kit, FogBuster Coolant Kit and PathPilot Operator Console).
    Given that, it seems to me an easy decision to get the Haas, as my understanding is that it is a much better machine overall. The Haas has 7.5 HP vs 2 HP for the Tormach, though the Haas EDU only goes to 4,000 RPM vs the Tormach 10,000 RPM. The Haas also has a bunch of features that the Tormach doesn't have (such as Safe Run).
    But John Saunder's advice on buying a Tormach vs a Haas (Buying a CNC Mill: Tormach VS Haas - NYC CNC) gives me pause: he advises that if you are asking yourself the question, get a Tormach. Also, I am a little worried that inexperienced operators might damage the Haas machine and lead to the need repairs which would be more costly than if I got the Tormach.
    What do you think? For a makerspace, is it better to get a Haas Mini Mill EDU or a Tormach 1100 MX?
    Oct 2009
    Oregon
    6,156
    6594
    3487
    So you will have people paying for time on this machine with some guidance?
    Why the hell would you want some hobby piece of shit then?
    If someone wants to make something from metal don't you want them to make it in a reasonable amount of time using professional tooling and toolpaths so customers stay happy?
    I would recommend a cheap 4020 machine from the 90's. Something Fanuc with a 40 taper spindle that has both a reasonable top end RPM and a low cost to repair when it's crashed.
    I can't fathom not only having to deal with hobby projects, but also doing the machining on some pile of shit machine.
    Oct 2020
    Missouri
    24
    50
    Go with the HAAS. Much more intuitive and very low maintnance
    Feb 2021
    Massachusetts
    13
    Quote Originally Posted by Garwood View Post
    Ok, thanks Garwood. Something like this Fadal: Fadal VMC-4020HT | Fabricating & Production Machinery ?
    Feb 2021
    Massachusetts
    13
    Quote Originally Posted by ElCrasho View Post
    Thank ElCrasho. Good to know.
    Apr 2012
    antelope ca
    23
    22
    8
    I helped a makerspace install a tormach 1100, I would get a Haas
  7. Likes john.obrien, bloomautomatic liked this post
    Oct 2009
    Oregon
    6,156
    6594
    3487
    What concerns me is that you should have no problem picking a machine if you are capable enough to offer it's services to your members.
    If you're thinking it's easy and you'll just figure it out as it goes I don't think it's going to go so well for your endeavor.
  9. Likes Cole2534 liked this post
  10. #8
    Nov 2016
    North Carolina
    312
    98
    146
    The whole point of these places is to learn, not to make a living getting parts out the door. The OP doesn't have to be a master machinist, just needs to be one step ahead of the guy paying for the opportunity to play with the machine.
    And buy the Haas, obviously. I like NYCCNC well enough, especially his tours, but you do realize he's sponsored by Tormach? That might color his views a little.
    I would not buy an older machine or anything Fanuc. The online video references alone are enough reason to go Haas. The only other machine you might consider is a Haas TM-1, just to give you more room. Slow rapids are going to be your friend.
  11. Likes TeachMePlease, john.obrien, bucktruck liked this post
  12. #9
    Feb 2021
    Massachusetts
    13
    Thanks Garwood for the feedback.
    While I am not a master machinist, I have been doing hobby machining with an LMS 3990 that I converted to servo CNCs for a few years, so as LOTT noted, my goal is to stay one step ahead of others who also are interested in learning more about machining.
    I would someday like to be a master machinist, but currently do not have access to the kinds of machines which would allow that. One of the reasons I am interested (and think others might be interested) in having a mill in a makerspace is to afford them the opportunity to get introduced to machining, and possibly someday become a master machinist (a guy can dream).
  13. #10
    Feb 2021
    Massachusetts
    13
    Quote Originally Posted by LOTT View Post
    Ok, thanks Lott. I will take a look at the Haas TM-1.
  14. #11
    Apr 2007
    Pillager, MN
    6,323
    1931
    6158
    Haas would be a much better choice................in a Makerspace scenario a machine will see a rough life. Not due to spindle hours, but neophyte operators............... the Haas should take a hit or crash better than the Tormach.
  15. Likes john.obrien liked this post
  16. #12
    May 2011
    New Jersey
    3,002
    301
    1654
    Quote Originally Posted by john.obrien View Post
    Hi All,
    But John Saunder's advice on buying a Tormach vs a Haas (Buying a CNC Mill: Tormach VS Haas - NYC CNC) give me pause: he advises that if you are asking yourself the question, get a Tormach. Also, I am a little worried that inexperienced operators might damage the Haas machine and lead to the need repairs which would be more costly than if I got the Tormach.
    Your first mistake is taking advise from Saunders...
  17. #13
    Feb 2021
    Massachusetts
    13
    Quote Originally Posted by metalmaster1 View Post
    Ok, thanks metalmaster1 for the advice.
  18. #14
    Feb 2021
    Massachusetts
    13
    Quote Originally Posted by plastikdreams View Post
    Is Saunders not a good source of advice?
  19. #15
    Feb 2021
    Massachusetts
    13
    Quote Originally Posted by david n View Post
    Okay, thanks david n for the advice.
  20. #16
    Aug 2002
    Regina, Canada
    2,582
    6
    119
    Tormach makes sense for entry level machine, delete all the options which in my opinion are not needed for your use. If I remember a tool changer is $5500 option. Do you really want inexperienced operators fooling with it? Their enclosure is not great save $2k or so, let the guys clean up their mess. They run on single phase might be an advantage depending on your power supply. PathPilot is a pretty easy controller to use, decent conversational and it includes a DXF program that will generate gcode from a dxf drawing. My final opinion scrap the whole ides of letting guys you don't know run any CNC machine.
    Bob
  21. Likes tdmidget liked this post
  22. #17
    Feb 2021
    Massachusetts
    13
    Quote Originally Posted by bob View Post
    Tormach makes sense for entry level machine, delete all the options which in my opinion are not needed for your use. If I remember a tool changer is $5500 option. Do you really want inexperienced operators fooling with it? Their enclosure is not great save $2k or so, let the guys clean up their mess. They run on single phase might be an advantage depending on your power supply. PathPilot is a pretty easy controller to use, decent conversational and it includes a DXF program that will generate gcode from a dxf drawing. My final opinion scrap the whole idea of letting guys you don't know run any CNC machine.
    Bob
    Ok, thanks Bob. I appreciate the feedback. I will provide training to them, and they will be paying me for the opportunity to use the CNC machine. I agree there is a risk. I'm hoping it all works out despite the risk.
  23. #18
    May 2015
    New Jersey
    95
    170
    38
    If you can actually get the Edu pricing on the mini-mill that's the obvious choice. You're getting a $10k discount. I'd be surprised if a Makerspace qualifies for that though, unless you are attached to a University.
    If you don't its a harder choice as then you are comparing a $20k Tormach to a $35k Haas. I'd still go for the Haas though.
    As for Saunders just pay attention to who he is sponsored by. Also look at what machines he's got in his shop now vs what he had when he was pushing the Tormachs. Keep in mind where he came from starting out in a NY apartment with a TAIG mill, a Tormach looks amazing when compared with that.
  24. Likes john.obrien liked this post
  25. #19
    Oct 2009
    Oregon
    6,156
    6594
    3487
    Why don't they call it a Learningspace then? Makerspace seems to imply people will be bringing in their DIY projects to make something no?
    If it is to teach people how to make stuff wouldn't it be better to do it with industrial hardware and processes?
    Kinda makes me think of my mega millionaire neighbor. His hobby shop is similar size as my for profit shop. He bought a Tormach and a bunch of harbor freight level machinery then he answered an ad for a machine I was selling and we met. He saw the difference and the increased capabilities you get buying quality used instead of new garbage. Now he's replaced most of his hobby shit with quality stuff and has something magnitudes more useful.
  26. Likes Oldwrench, Bobw liked this post
  27. #20
    Oct 2012
    Orange county, CA
    190
    10
    44
    get a bridgeport, or a even better, a tree.
    i saw a guy w/ a masters degree in mechanical engineering running the tree once. As he was lowering the saddle we start hearing CRUNCH CRUNCH CRUNCH. we're yelling STOP STOP he's just looking around wondering what's wrong, continuing to lower the saddle onto another guys laptop which was on a folding table, just underneath the mill.
    point is, this machine is bound to get hurt. you're better off hurting something cheap.
