noobie owner with a noobie question
is there a difference as far as how much to charge for a 2a class fit and 3a class thread fit
if so how much difference ?
So you want to charge more to add or subtract cutter comp....interesting...
I still don't see it...
A 2A thread is external, threading insert (turning) adjusted with comp. Thread mill (milling) adjusted with comp...
If it was 2B or 3B, internal, that is driven by tap size (GH number) chosen for the appropriate tolerance and material. Or if the thread is big enough to be thread milled, again cutter comped to meet the gage size.
Regardless I just don't see how it would affect pricing...
The only variable I see would be if the thread was going to be thread rolled and you have to hold to the tenths on your size, but that is a hole different process animal with it's own costs etc. and 2A, 2B, 3A or 3B should have no bearing on cost I wouldn't think. Let's see what he comes back with...
Any supplier telling me that it didn't matter whether I ordered 2A or 3A and that the price would be the same would be put in the WTF category.
I'm the supplier that would tell you that it didn't matter....
Then I read your reasoning... Since you are "the thread guy", you see it from the thread side, I'm a "parts" guy, and
I see the whole part...
You are correct in a way... The stuff I deal with that has a class 3 thread on it.. The threads are usually the
easiest thing to deal with, and those parts are going to be inspected with a fine tooth comb.. I'm going to pay just
as much attention to the threads on "those" types of parts weather class 2 or 3... So it really doesn't matter 90% of
the time.
Toss a J in there with the class 3 (and I know all J threads are class 3) and the price goes up a bit,
need to buy the right inserts and keep real close attention to the tip of the insert, one tiny chip, or some build
up, and that stupid tight tolerance root radius is shot.
The types of parts where they hand you a nut or bolt and say "this has to go on/in there". Much lower price.
I didn't quite "get" your post. If you didn't need a 3A tolerance would you really make that your call out?
I'm with you on this one BobW. Quality is Quality and you use the appropriate tools to get the job done right.
Why would one treat a 2A thread quality any different then a 3A thread quality. Parts still need to meet the gaging requirements regardless, and it surely doesn't take any longer to spin the go and nogo gages to verify either thread type.
Its kind of like ±.001 or ±.030 on a simple short pin... Cost won't change, I'm going to hit it within a half anyways.
I am guessing though that you aren't always the one giving the lowest offer.
If I could "like" this 1,000 times, I would.I try not to be.
I have his ThreadPal program and it saves me time from having to go through my thread library. OTOH if I want more info than "just" tolerances then I have to read.
Should have bought it years ago. It really is a time saver.
Notice
