Fire Extinguishers, What types should be in the shop ?
Results 1 to 17 of 17
    May 2007
    Massachusetts
    1,445
    512
    1261
    Default Fire Extinguishers, What types should be in the shop ?
    Guys,
    I am in need of some information on Extinguishers. I did a search and read quite a bit but it's not clear to me what types to have in the shop. Some just referred to dry or ABC.....?
    We are moving into new space it's a sweet deal for us but everything needs to be 100% code. I was asked yesterday what type/types of fire extinguishers we required, how many and where they would be located on the floor plan.
    Our new shop is currently being constructed on the fourth floor of a building that was originally built in the 1940's to service and supply the U.S. Navy on Bostons water front. The building is built like a brick shit house all concrete and steel construction.
    We have four CNC lathes HAAS SL-20's and Hurco TM6 machines. We also have four CNC Mills HAAS VF-2SS machines. We have two ProtoTraks and two manual Hardinge lathes along with a vertical and horizontal band saws.
    I was thinking we should have at least four CO2 and an equal number of dry Chemical extinguishers. My question is What type of dry Chemical extinguisher should be used in the shop ?
    Thanks for the help !!
    Make Chips Boys !
    Ron
    Apr 2015
    Tennessee
    149
    100
    25
    We have ABC in ours but also was told we might need a D since we cut a lot of aluminium. Since aluminium "dust" is in with titanium and magnesium.
  3. Likes Eric M liked this post
    Mar 2010
    Davidson NC USA
    1,494
    587
    909
    Instead of guessing and asking the crowd, have you ever thought of contacting a fire protection company to get their take on what is needed, and the best layout for most protection? You do not want dry chemical anywhere near your CNC equipment.
  5. Likes digger doug, sfriedberg liked this post
  6. #4
    Nov 2008
    Madera county california usa
    2,610
    21
    674
    We service many fire houses and they often are looking for interesting things to do.
    Part of their job is fire inspections.
    Ask if they can pre-inspect before you move in as they can assist with layout for code requirements and sprinklers or other items you are not thinking about.
    They can advise on what is needed where for suppression and first aid.
    It often makes their day as the would rather direct on the front end than enforce on the tail end.
  7. Likes tdmidget, Steven-Canada liked this post
  8. #5
    Jan 2014
    Temecula, Ca
    3,280
    1398
    4289
    Or, you might just call a fire protection company. They know the codes and can tell you what you need and where. Then, they'll come back every year to keep your tags current.
  9. Likes Dualkit, Steven-Canada liked this post
  10. #6
    Sep 2006
    Sacramento County, California
    4,189
    2661
    1567
    I presume that you will have employees and therefore will have workers compensation. A phone call to the workers compensation insurance company should get you a free inspection as well as recommendations about fire extinguishers.
    By the way, how do you get your CNC machines up to the fourth floor?
  11. #7
    Dec 2003
    Washington
    5,017
    2590
    4752
    Massachusetts. . . you will need a certificate of occupancy and this will be predicated on a fire inspection done by the local fire marshal . . . generally they have rules like the following:
    FX must be placed with the handle no higher than 60 inches from floor
    FX must be placed within sight (use elevated signs where necessary) visible up to 70 feet away.
    FX must be within 70 feet of walking distance from any location in the shop for general use
    FX must be within 30 feet of walking distance in areas designated for welding
    FX must be 10 lb capacity or larger in shop areas
    etc.
    We just went through this in our new facility. I have a good friend in Sudbury Mass who recently retired as Fire Chief and he often told me about inspections where building tenants were completely in the dark on requirements. . . The fire marshal is the guy you need to make happy on this score.
  12. Likes TeachMePlease liked this post
  13. #8
    Sep 2008
    2,213
    1576
    1360
    Quote Originally Posted by sealark37 View Post
    Unless the shop or cnc's on fire, then you can worry about the mess and damage to the CNC's afterwards.
  14. #9
    Oct 2013
    New Jersey
    1,249
    1089
    We had a fire inspector come through our shop once. He wrote us up for having extinguishers mounted too high. Dad says to the guy how many are we required to have? Guy says three. Dad says how many were mounted too high? Guy says six. Dad asks how many did you find? Guy says 17! Dad says fine you can report 11 working extinguishers, those other six are wall ornaments, I collect fire extinguishers.
  15. #10
    May 2009
    Wyoming
    3,552
    8852
    5782
    Quote Originally Posted by garyhlucas View Post
    Even though we have many more extinguishers than required, we found out it's not permitted to keep out-of-date ones on the premises even if they are in working condition (by out of date I mean too old for refilling/recharging). His advice was to just give them away to people to carry in the trunk—not regulated and can't hurt.
  16. #11
    Sep 2007
    Northern Illinois
    2,988
    1629
    1809
    All ours are located adjacent to our exit doors, at the suggestion of the fire marshal, on the theory that you run to the door to get the extinguisher, and once there you can make the decision to use it or keep on going. It helps prevent going deeper into the shop and becoming trapped by the fire. All ours are ABC. If I ran enclosed CNC machining centers I would consider adding CO2 extinguishers right by the machines... if the fire is inside the enclosure the first extinguisher at hand is also the most machine friendly. If the situation gets out of hand, the grab the ABC by the door.
    Dennis
  17. #12
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by Newman109 View Post
    One doesn't.
    Lower the building so 4th floor is at ground level. Roll them in on ignorant skates. Raise the building back up.
    How hard was that?
    Otherwise, just engage a less lazy rigger with fancier gear and lower aversion to a bit of sweat.
  18. #13
    Jan 2014
    Temecula, Ca
    3,280
    1398
    4289
    shit, I had to re read that sentence a little more carefully
  19. #14
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by Larry Dickman View Post
    Not entirely a joke. If that building is a structural cousin to the US Navy's former "Torpedo factory" near Alexandia, VA's waterfront, it had freight elevators appropriate to its tasking from early days.
    It really COULD be as simple as machinery skates and a button-push.
    If over the mass limit, one schedules out-of-hours, rigs beams and cable from the top of the lift shaft, lifts the load inside the shaft space, slung independently of the cab or even UNDER the cab.
    Next option requires a crane, plus roof cut out and restoral. Or similar, exterior wall.
    Weirdest one I had on my plate, Marquette Building, Chicago's "loop" area, early 1980's, we had to;
    - long-term lease a specific carpark slot.
    - In which, a thick steel plate was grouted, spreader beams atop.
    - ONTO which was raised a steel beam to a smaller steel plate grouted to the undersdide of the floor above.
    All in order to prevent 5800 Avoir ++ of Mosler TRTL-30 joolry safe from dropping right through the old concrete floor upon initial installation!
    Store Project Manager had been telling me for three months "No Problem!". Finally told him no Engineer sign-off, Lang wasn't moving the box outta the rigging warehouse, he couldn't open the damned store.
    So he gets the right RPE's onto the site. Finally.
    Calls me back.
    "Engineer said I was right all along,
    Put the safe there, "no problem".
    It will drop straight through the f*****g floor!"
  20. #15
    Oct 2005
    19,586
    Yup, was in an older industrial multi story building.
    The one elevator was a repurposed freight elevator, they had gotten rid of the "open car,
    pull the door closed with a hook" set up, and it had a modern, well lit car with automatic
    electric doors.
    Except the capacity was retained, the chart updated from "tons" to "passengers".....85 people to be exact....
  21. #16
    Virginia
    16,233
    7561
    10820
    electric doors.
    Here's the one locally. Built at the tail-end of War ONE. so Boston's may be newer:
    Alexandria's Old Torpedo Factory — Architect of the Capital
  22. #17
    Oct 2005
    19,586
    Re-read the OP....and no mention of what's flammable.
    Materials ?
    Coolants ?
    Loobs ?
    Figure out what is going to burn in your shop, and then go get a extinguisher
    for that.
