Got a bunch of quotes and cant find material.
Why is 2014 T651 AMS-QQ-A-225/4 so hard to find same goes for 2024-T851 not to mention it has to be USI ultrasonic inspected.
Little better situation with 7050 but still out of 6 of my vendors only one sent me his quote and he is like way out of state.
Anyone has a supplier they would share info.
I feel your pain on that one.. Spend more time trying to find the material than actually doing the job,
and after you've wasted a ton of time, with no success, you go back to the customer and they say, "Oh you
can make it out of this COMMON, EASY TO GET material".... That's why "generally", if I can't source it quick
and easy, I quote "machine only", and I know for some that isn't an option...
I suggest getting a copy of one of the aluminum heat treat specs.. I've got mil-h-6088 on my desktop..
Its free at everyspec. And then you can work your way through the heat treats.. Sometimes, like
with 2024 T851, its not that common, and you end up buying some T351, and then its a simple time and
temp to bring it to a T851... 12 hours at 365 to 385.. Same with the 2014 T651 is a T451 cooked
for 10 hours at 340-360.
What sucks is when there is that little extra hanging '1' on the end, like T6511, which is basically
the same damn thing, but it was straightened or some stupid thing..
Also, on the ultrasonic inspection.. Ask your supplier, most of the folks that are supplying
certified material *SHOULD* understand this, and they *SHOULD* have a vendor that can supply the
service before they even ship you the material.
