Within' the last 2 years the business i work for has just exploded. Thanks to our weak dollar our overseas market just exploded. over half of what we are doing is going overseas. 5 years ago we were lucky if we sent %10 out of country. I work in the machine shop, we're a production shop. the past year we've been farming more and more parts out to job shops around our town. Currently have 3 of them which do certain parts for us. 2 of them treat us right. The other is a bit on the high side but he does good work and always has our stuff done when we need it. Our shop cannot handle the volume that we need to do. Our boss refuses to start a night shift and to be honest we could really use one right now. Thats a whole other story...
Just recently we got a quote for a part that we run and are currently running. Its just one of those things that takes about 30 min for 1 finished part. 10 hr day you get 20-22 parts a day. And this is running 2 ops on a 40 taper Vertical mill. Just recently built a fixture and tooled up our HCN6000 to run 1st op 2 parts at a time in it. Which knocked off 5 min a part just on the first op. What would most of you charge for a part that takes 30 min to run? We're not talking anything complex... its an Aluminum casting, some face milling drilling and tapping. 2 circed out holes that have a +.003 tolerance, the smallest being 3.000". With that loose of a tolerance i won't even mess with a boring bar. I know most shops around here are $60-80 an hour shop rate. The quote we received back from one place was $88 a part. I about died laughing. This isn't the first time either... Another part was this little 5" x1.25" piece of 1045 round stock. Our run time on our lathes for a finished part was 4-6 min depending on which part it was. This is just turning time. This shop wanted $18 - $22 a part and this was with us supply supplying the already cut material. we're talking 10-15 parts an hour... Thats a $220 an hour shop rate. This round stock isn't a complex part. It shouldn't take more than 15 min to turn down a set of soft jaws and another 30 tops to write a program for these parts. Setup couldn't take more than an hour and that is being generous.
The way we see it if places are wanting to charge this much we might as well just get use to working 60 hours a week because its cheaper for them to just pay us the overtime. which quit frankly i'm tired of... after 2 years of at least 50 hours a week and here lately 60 hours i'm ready to go back to my 4 - 10's and enjoy my 3 day weekends. My thoughts are with the economy as bad as it is that some of these smaller places would want the work. Not crank their prices up so high that people don't bother. thats just me and i could be wrong. I do realize we're a production shop. I'm running 3-4 insert indexable endmills, 12 insert face mills, coolant through drills. We flat lay the coals to the parts we run to get them out as fast as possible. I know a lot of job shops aren't going to have the machines and tooling we have so higher cost is expected. just not double or triple of what we can do it for in house.
