I have an estimating spreadsheet in MS Works.
It is VERY, VERY CRUDE. Not more than 20 minutes in it's development.
It was done for jobs made from aluminum bar stock. These are in 12' lengths.
So, it calculates the weight of a bar based on the dimensions, times the price per pound.
It calculates how many parts you can get from a 12' stick, and how many total sticks you need per the quantities needed.
Next is how much (time) do you think it will take to make each part?
Can you make them cheaper if you make a lot of them?
So, what is your base estimate, and you minimum per piece cost for a large order?
How many parts will it take to get "smarter" ?
Basically, you enter amount you think it will cost to:
Set up the job.
How many parts per bar.
Size of the bar.
Cost per pound.
Minimum setup cost.
Base rate per part.
Cheaper base rate if you get "smarter"
How many parts to get "smarter"
What qauntities do you need numbers for?
And, you can cheat and lie to it about the material cost, so it gives an idea about material cost per part, which is what you want.
That's about it..
How do you come up with costs per part?
How may operations will it take?
How many trips into the vises?
Special vise jaws? Soft jaws?
How many drilled, Tapped, helicoiled holes?
How many tool changes per part?
Special tooling?
Figure so many cents every time you pick up the part.
So many cents each for every helicoil.
So many centes per bandsaw cut.
Finishes, plating etc.
Packing, shipping, paperwork for all outside operations.
Costs for paperwork, material certs, COC's etc..
All of that I usually do on a paper worksheet.. Every part is unique. More or less.
The spreadsheet is handy for crunching the numbers when they want pricing for every possible quantity possible. 1,2,5,10,20,50,75,100,150,200,300,500,1000, etc..
