Walk ins... UGH....
Inventors that want to "cut you in" on some of the profits when it "really takes off".. UGH..
"Well, BUT, I can buy one from XXXX for $100".. Well then, what the F* are you even doing here???
Go buy the freaking thing!!!!! Idiot..
I hate walk ins.. I really do.. I keep a really really low profile. Nobody knows what I do here.
So if somebody shows up here, they know somebody.. Had one that actually panned out the other day.
$120, had to do some paperwork to become an "approved vendor".. But in a backwards way, we had
a connection, and I had met him before. Might be a few dollars here and there down the line, never
going to be a million dollars, but.... ??? 20 minutes of setup, 24 minutes of run time. 20 minutes
to become "an approved vendor".. I HATE!!! paperwork!!! Tolerance of "Yeah that looks good".
Minimum charge.. Well that is a whole other can of worms.. $200 sounds perfectly fine when you
have to do the standard BS paperwork, the CoC, the inspection report, quote it blah blah blah...
Even if the job only takes me 5 minutes.. The Bull Shit takes $190.
Then.. There are other customers.. The ones that are never going to make your rich, but will never
make you want to shoot yourself in the head. The ones, where if its a complicated part, will be sketched
out, otherwise, some Sharpie marks and a mating part, and a tolerance of "make it work"... I got a 36x48 inch
piece of paper, freshly drafted, BY HAND off of a drafting table last week. And its work after work after work..
COD.. But I just save it up. Check when I need it.. Some little stuff is $15 total.. Some is $3000. Some turn around
is NOW!!!!!(3 times today) Some of it is months.. A lot of it easy, a lot of it I have programs for. A LOT!!! of it
is F'n Keyways.. I have that shit down to a science. And its farmer tolerance. Super deep, super wide. So like 2 to 5 wide, and 15 to 25 deep.
Its cool when you walk in (4/10's of a mile down the road).. And say, "Hey, can I get some money today".
And they reach for their back pocket, pull out their wallet, and say "how much you need"? ... NO, an invoice,
and a check.. "Sure you don't need anything right now?"...
Best customers EVER!!!!! I say customerS because its a father and son. Very rarely do I quote.
I try to keep the prices low when its part of an assembly they have going out, but they let me know
when its a pass through and I can really hammer it.. Been more than once, repair parts were needed
as a pass through, and it was casually mentions that some of those same parts would be needed for
a machine coming up in a few months.. Cool.. 15 parts(plus setup) at $50 and 35 parts at $10(on a
separate invoice)...
Minimum charge on their stuff. $10.. If its a stand alone part, maybe $20 or $25. I'm thinking keyways
mostly. A quick little stupid thing here or there, I won't even charge them.. However, their $10 job, for
some of my other customers could easily be a $300 job, for the EXACT SAME THING.. 2 minutes to set it up,
2 minutes to run it.. $10... Add a pile of paperwork, inspections and paperwork and bullshit, $300.
It could be the EXACT same part, and I honestly probably pocket more money charging the 10 than
the 300 when all is said and done.
So.. The answer is.. it depends on the customer. I hate writing a single invoice for under $200.
