Number of Quality Control personnel vs Machinists
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Oct 2011
    Champaign, Illinois
    30
    13
    8
    Default Number of Quality Control personnel vs Machinists
    Just curious how many Quality people you guys have vs how many guys are making parts.
    We have about 25 guys making parts during the day,2-3 robots loading mills at night, and gobs of live tool lathes and swiss machines, with 2 guys trying to check everything.
    It is regularly a bottle neck and I'm just curious how far off the mark we are. I know it depends a lot on what work you're doing. Well we do a little of everything, with an increasing stake in Aerospace and Defense contracts, all the while working on ISO certification. I know we need at least one more guy but I even question if that is enough.
    Again, I'm just curious what others are doing and other opinions.
    Thanks in advance.
    Feb 2013
    Madison, WI
    978
    1118
    633
    Are these just first piece inspections, or are they also supposed to do all in process inspections? How many setups do you average per day? How complicated are the parts? How long is your average production run?
  3. Likes Dualkit, Gordon B. Clarke liked this post
    Feb 2005
    Akron, OH
    1,835
    280
    1380
    Also how complicated are their inspections? One diameter with calipers or 800 points with a manual CMM?
    If they're working efficiently and they're the bottleneck, then add another one. Who cares what other people are doing? 25:3 doesn't sound unreasonable at all. For whatever it's worth, our ratio is 6:1
  5. Likes hanermo liked this post
  6. #4
    May 2017
    Minnesota
    989
    1192
    611
    Are they doing everything manually or do you have a CMM / vision system?
  7. #5
    Sep 2009
    barcelona, spain
    2,381
    530
    1431
    You stuff sounds like high end work --
    but may mean nothing.
    In-machine probing might qualify 99% of the parts, or features, .. or not.
    Endless ways exist to improve stuff - sometimes vastly, depending on what is being measured and qualified.
    E.
    A ring gage on a cnc with touch probes, might prove outer D and some other critical features, fast.
    Cylindricity, roundness, surface finish would not likely be qualified. Nor tir.
  8. #6
    Jan 2007
    Flushing/Flint, Michigan
    7,723
    385
    6439
    Quote Originally Posted by Comatose View Post
    So in a 600 man shop you would have 100 inspectors?
    Bob
  9. #7
    Jan 2003
    Canada
    11,204
    5285
    3355
    Well, if you're getting NCR's from customers, definitely up the quality control.
    If everyone's happy with the quality and almost never anything coming back, I guess it ain't too bad.
    2 final inspectors for a 25-30man shop seems average. Ideally the parts should be good before they get to them...
    See if there's any inspection equipment you can add to make it faster/easier.
  10. #8
    Feb 2005
    Akron, OH
    1,835
    280
    1380
    Bob
    No, literally it is 6 operators to one inspector here. But for a 600 person shop, if they were doing all one-offs with 100% inspection? Maybe!
  11. #9
    Mar 2011
    SWITZERLAND
    1,003
    122
    412
    Better hire better machinists. The ideal would be that the makers make good parts in the first place. It’s the old-time approach, check everything that goes in 100 percent, then nothing bad comes out. The contrary is chaotic manufacture and completely overburdened QM.
    Material, workholding, tools, tool holders, strategy, speeds, feeds, coolube, something like that
  12. Likes yugami, pmack, DieselMater86 liked this post
  13. #10
    Aug 2008
    Chicago, IL
    166
    30
    34
    What are you measuring after making parts and why? What value is this creating to ensuring that the parts being produced are good.
    Who owns the outcome of the production process? The QC guy or the machinist? If they're real machinists, can't they measure? If the parts are bad are these guys hanging out until someone tells them what to do?
    Proving out process capability will allow you to sample instead of inspect 100%.
  14. Likes 4 FN 27, Gordon B. Clarke liked this post
  15. #11
    Aug 2010
    Medina OH
    1,782
    131
    759
    Everywhere I have worked, I was required to QC every part I was capable of measuring.
    While some of the very complex parts I was not able to measure (such as what was run on 5 axis) I was usually given datum by the programmer, designer, or someone, to then be able to verify that in THEORY the part was good. Final verification by QC dependant of course.
    Batch runs, I would check all the details that I could, typically if 1+ aspects were good... USUALLY that meant the others were good too.
    Typically if it was a complex form, I was hard milling or hard turning, so could measure certain aspects, if HIGH precision, the forms, contours, cutting edges got jig ground after I was done with it.
    So, like the questions above, are these people machinists or operators? Even in the production environments I have been in, the operators are required to make continued checks. QC should be doing verification checks, not complete inspections.
    We have a 1:1 inspection ratio here....
  16. #12
    May 2009
    Wyoming
    3,225
    7810
    5189
    Quote Originally Posted by SND
    Quote Originally Posted by mechanola
    Quote Originally Posted by yugami
    I've always thought that QC inspection after the fact is a hell of a risk. Working drawings should contain enough data to allow in-process inspection and the machinists should be able to do that. It's the reason for calibrating their tools.
  17. Likes 4 FN 27, DieselMater86, tdmidget liked this post
  18. #13
    Oct 2007
    SPAIN
    3,382
    1869
    1226
    I've worked for a couple of USA owned UK divisions, and on the whole the UK is stripped right down.
    In going to the US companies USA sites, they tend to have QA personnel level at 10% of the headcount.
    This is Aerospace OEM type products - black box instrumentation etc.
    I believe Sikorsky also run the 10% rule too.
    But that's not just inspectors, it's QA engineers too.
    To the OP, 2x inspectors for that many machines is not enough.
    I'd be thinking 4x Inspection and a hands on QA manager.
    And a couple of the Inspection should be roving - picking up mid batch parts to look at...
    You have to have holiday and sick cover...
  19. #14
    Mar 2017
    Minnesota
    124
    60
    117
    We are a fab shop. Our Set-Up Personnel are responsible for 1st part sign off. Then the Operator is instructed on the measurements to be checked and the frequencies. Final Inspection is an audit only. Basically making sure all the router oops are signed off and nothing is missing.
    We have 73 fabricators on the floor...when a customer asks "How many Inspectors do you have?" My answer is 73 and 2 auditors in Final Inspection.
    Quality is built into the parts via Machine Capability, Process Refinement, training and setting expectations. Hard to inspect quality into the parts once they are complete.
  20. Likes yugami, tdmidget liked this post
  21. #15
    Feb 2014
    UT
    553
    102
    OP, I think you have asked the wrong question. The right ones would be about how many machines and how many parts along with the complexity. Basic 2 op, 2D parts are much easier than complex 5 axis parts with tight controls. The drawings are also telling. a +/- .005" hole will be inspected different than a /- .0005" hole.
    It sounds like your quality guys are doing their job and not rushing to pass parts. If it holds up the train, get help. While we push operators to inspect at machines and give the tools to do so, there is NO WAY we will pass any part until it goes through inspection by a competent person with proper metrology background. You don't check a hole diameter with a caliper, yet I see it all the time.
    I would personally be looking at new measuring equipment to accelerate the work.
    We also have an inspector on the floor that moves around and double checks operators and looks for concerns. If a hole is hugging bottom of tolerance, some questions may get raised how old a drill is or if changes need made. I know one plastic part we do where the drill size was increased to what should be max size but the plastic shrinks back down after drilling so they come out perfect in QA.
  22. Likes mhajicek liked this post
  23. #16
    May 2010
    DENMARK
    3,277
    4017
    12712
    The best reason for having any QC is to avoid stupid mistakes being repeated. Corrective action is very important. What went wrong and why?
    If QC is to babysit machinists then you have the wrong machinists.
  24. Likes barbter, DieselMater86 liked this post
  25. #17
    Feb 2014
    UT
    553
    102
    Quote Originally Posted by Gordon B. Clarke View Post
    Thanks dad. I think we got it covered.
  26. #18
    May 2010
    DENMARK
    3,277
    4017
    12712
    Quote Originally Posted by huleo View Post
    Doesn't sound like it to me kiddo.
  27. #19
    Feb 2014
    UT
    553
    102
    When you write a book, please let me know so we can all be like you.
  28. #20
    Jan 2007
    7,723
    385
    6439
    ...... If a hole is hugging bottom of tolerance, some questions may get raised how old a drill is or if changes need made...... .
    Ouch..
    Why is the machinist or even button pusher operator not trained enough in QC to complain loudly about such.
    Why would you need a "special" person?
    If your measuring goes into a computer why does it not raise a big red flag?
    You simply should not have this as a concern. Ask yourself and your system why.
    I disagree with Gordon on many things.
    A book or long desertion on the net of his views and experience would be much welcomed.
    Why do people not "ground" their machine staff in 6-sigma, measuring, temp comp and variations?
    Most of these guys/gals on the floor and doing the work really, really want to make "perfect" parts all day long. Walk a mile in their shoes.
    QC is a verification, a second look.
    When it bounces why?
    The floor screwed up is not why.
    Perhaps you fire the guy who ran it. That all feels good but not sure it plugs the real hole.
    Bob
  29. Likes tdmidget liked this post
