IMHO correct sizing is everything with a screw - any larger industrial compressor, they don't like stop and start. They especially can not tolerate only intermittent run. Its a fundamental nature of the way they lubricate them selves. Equally they have a fair bit that kinda goes wrong. If you only genrally need a little air 4 days a week then a lots one day, you need a system with 2 separate compressors. Trying to do it with just a large one will cost you more in parts and electric down the road unless you put in large air storage.
Me i like hydrovanes, sure there not as efficient as a good screw, but so long as you keep on top of the oil changes and they run long enough cycles to get upto operating temp to keep the oil dry they just go forever. Like screws a key part of that means that if your only using it intermittently, you need it inside the heated space, not outside in a typical compressor enclosure so it can stay at correct running temp. Soon as you start building moisture up in the oil your heading for problems with any compressor.
As to screws taking out shaft seals in less than a 1000 hours, sounds like a major issue either alignment or a design failure or a back pressure issue.
