Programming Room or on the Shop Floor
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Apr 2019
    Massachusetts
    Default Programming Room or on the Shop Floor
    Majority of programming done on the floor or in separate programming room ?
    Dec 2008
    New York
    10,392
    2699
    Quote Originally Posted by Fitzmach View Post
    depends on how large and or complex the part. simple small parts can be done on the floor. large parts with thousands of features take time and often are done in a office
  3. Likes barbter liked this post
    Oct 2005
    18,835
    Quote Originally Posted by DMF_TomB View Post
    Yup, do you want a file that works correctly ?
    Would you like it optimized to make you money ?
    distractions come easy these days
  5. Likes toolsteel, Laurentian liked this post
  6. #4
    Dec 2008
    New York
    10,392
    2699
    many simpler parts are conversationally programmed in less than 1 hour (many take only 5 minutes) while the same machine is also machining other parts.
    and any parts scrapped, most cnc machinist can create a program to rough out a blank of the size needed in less than 2 minutes so the scrap part can be remade.
    that said a 2 ton parts with thousands of features might take days or longer to program. that is not normally done at a cnc conversationally.
  7. #5
    Jul 2012
    Washington
    3,190
    1280
    1376
    At my last job we started out on the shop floor but all the noise got old so those of us doing the programming moved the pc into a corner of the assembly room. It was much nicer not being next to the machines while programming, and far less distractions.
  8. Likes M.B. Naegle, digger doug, toolsteel liked this post
  9. #6
    Apr 2005
    Beaverdam, Virginia
    9,059
    1130
    4597
    The fewer the distractions the better.
  10. Likes M.B. Naegle, toolsteel, Laurentian liked this post
  11. #7
    May 2004
    2,516
    886
    1644
    This is me programming. I get distracted thinking about unicorns a lot though. Life is, like, really hard.
  12. Likes barbter, TheWolfOfWalmart liked this post
  13. #8
    Feb 2011
    2,568
    2110
    1139
    We have our Cad/Cam computer in a shop office in the machine shop, which helps when we have some back-and-forth going between designing a part, checking a sample on the granite, measuring a fixture, and then going back to designing the part. As others note, as little distractions as possible, but keeping the design process closely linked to the physical shop is a plus.
  14. Likes Laurentian liked this post
  15. #9
    Mar 2015
    Michigan
    468
    110
    174
    Quote Originally Posted by [email protected] View Post
    I'd take a hefty pay cut to do some "programming" in that office.
  16. Likes [email protected], toolsteel liked this post
  17. #10
    Jun 2011
    New Jersey
    1,071
    671
    424
    Depends.
    Simple stuff - shop floor.
    Anything that really requires me to "write code" I do in the office.
  18. Likes toolsteel, Laurentian liked this post
  19. #11
    Sep 2018
    78
    51
    16
    How many employees do you have programing? We have 15 guys that do all their own programing (no production work), one or two computers doesn't work for us. Each guy has a computer on their desk where they do all the programing/analyzing. We did this so guys didn't have to wait until the other guy was done with the computer. I recommend the shop floor.
  20. #12
    Oct 2007
    SPAIN
    4,236
    161
    88
    I had two workstations - one on the shop floor amongst machines. This was great for simpler work, and any edits required and also the operators could run through solid verification right next to the machine they were proving out on.
    Complex jobs and more "engineering" type work was done upstairs out of the way.
  21. Likes Chazsani, toolsteel, Laurentian liked this post
  22. #13
    May 2007
    2,599
    3054
    479
    What the breakdown is where I have been mostly has been that Programming (2 People) will program most of any new jobs that come in. Then the program is set up and proven out then if it makes good parts it is kept on computer and used. Since there is a massive amount of established jobs and customers the things run have already been used and improved.
    New jobs can take time especially with complex parts that come in. Never are such parts programmed at the machine totally anymore as it is considered non productive.
    Bottlenecks will happen in programming when they are swamped. Also despite proven programs things happen and so changes that need programming must be squeezed in on the fly. There is no software for the guys in the shop to use or learn which is seen as wise because of the lack of experience from unseasoned programmers.
    Most programmers I know do not like to come out to the floor. If they do they try to avoid getting involved with much drama because it may not need his attention yet so give it time for them to take responsibility.
    The tendency is to get the fellow (programmer fellow or lady) come over and the programmer can hardly get a cup of coffee without being diverted.
    However it is done it should always boil down to what works best for the shop. Finding out the best thing may be real tough especially if the shop has work in high demand and of a time sensitive nature.
  23. #14
    Nov 2012
    Wisconsin
    2,164
    3555
    2700
    I do quite a bit of programming. 80% of it with CAM. 100% of it is on the floor. I am looking at the machines as I write this, eating lunch at my desk. At times it is a good thing to be on the floor, I get to hear how things are running.....I am right in the thick of things. Then there are other times when I would like someone to know just how much time I piss away re-doing, re-thinking things because someone sees me sitting here and decides to ask tooling or program questions....some of which are good questions...some not so much. Or trying to sit here working out a 5 axis tool path while the guy running the machine 20 feet away doesnt seem to realize that he doesnt have to pinch the air gun full blast...it works without being full blast too...lol. The part that bothers me most is that I know for a 100% fact that the quality of my programs suffer with every interruption. We have probably about 6 or 7 other guys in the plant doing similar.....I wonder some times if we were in a central location would we be able to learn from each other....or maybe just learn to hate each other...what I do know is that my employer will never have the programming being done in an office setting. I believe it is in part because of the optics of how that looks...possibly a status thing as well.....from my perspective, in order to do my job as best and as efficiently as possible, I would have two programming stations, one near the machines and another in an office setting...
    my .02 cents....entirely worth what you paid for it.
  24. Likes cpifer3, Shawnrs liked this post
  25. #15
    Nov 2012
    Wisconsin
    2,164
    3555
    2700
    Quote Originally Posted by Spinit View Post
    Once again...just my opinion. I started my career as a machinist. I have ran manual machines and 5 axis mills and Multi Task. My "home" has always been on the floor. I wouldnt consider having a programmer who didnt do something similar. Not sure I will express this quite right....learning the mechanics of how to program is a different task than learning what tools, speeds, feeds, and strategy to use. I could never learn the strategy etc from a book....maybe others can.
  26. #16
    May 2007
    2,599
    3054
    479
    Quote Originally Posted by toolsteel View Post
    There is a lot of value and much respect by being on the floor. As you mentioned it has definite advantages doing so. Also I have seen when programmers can not get to privacy or interruptions constantly especially when working on a program for a new and complex part. I feel for them because I see what they must deal with.
    I think the chance (at least occasionally) to have a office off the beaten path yet accessible to those in the shop would be positive and productive for the process.
  27. Likes toolsteel liked this post
  28. #17
    Nov 2014
    Florida
    5,147
    2045
    2510
    I'll second that. If I'm puzzling out the best path for something and get interrupted 3-5 times, it sux.
    I don't do alot of complex stuff these days, but I do alot of similar parts, which have their own downfalls. When you have programmed the *same* operation on 50 different, but very similar, parts sometimes you go on autopilot and miss a little detail.
  29. Likes toolsteel, Shawnrs liked this post
  30. #18
    Aug 2010
    Medina OH
    2,274
    292
    1097
    Oh yea... its great when you have a 4 year old who is already more intelligent than you ask you the most random questions every 10 minutes ranging from how does electricity work to why, if Thor is a God, and Thanos couldn't kill him, did Jesus die? Or needs Milk. Or needs a lego unstuck. Or needs you to hold a funnel so she can pour sand in a container to build a castle.
  31. Likes TeachMePlease liked this post
  32. #19
    Nov 2015
    Oklahoma
    311
    70
    145
    We had about 60 programmers supporting several different locations in the plant. We found in our case that one or two programmers trouble shooting on the floor in each area and the rest in the office without distractions worked the best.
    I also rotated people supporting the shop floor. Personality traits, sometimes with the machinists and/or sometimes with the programmers and/or sometimes both, could lead to its own set of problems.
  33. Likes ratbldr427 liked this post
  34. #20
    Mar 2011
    MASS
    981
    426
    309
    Did I see your Ad on my facebook feed,
    Do you guys have a bunch of Index Machines?
