Savings on powering down machines at lunch
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 79
    Mar 2018
    Illinois
    Default Savings on powering down machines at lunch
    I’m looking for advice on wheather or not to power down 8-10 machine when everyone is at lunch. Trying to decide which is better. Less power consumption vs machine sitting idle with electric, lube oils and such just running.
    Jan 2013
    Plainfield, Indiana, USA
    1,574
    1154
    812
    Next time you idle machines, like for lunch, note kwhours on your electric meter, then read again when lunch is over. From your light bill you can determine the average cost per kilowatt hour.
    Now compare this to the labor hours lost turning machines back on and waiting for controls to boot.
    I bet I can guess the result.
  3. Likes mhajicek, Chazsani, MetalCarnage liked this post
    Oct 2005
    10,232
    17296
    5312
    Stagger the lunch break times, the half of the employees still at
    the machines, can double up tending the other half, and then reverse
    for the second half of lunch time.
    Mar 2011
    Geneva Illinois USA
    4,852
    1913
    1813
    You might want to do it half way. Shut off the motors and such but leave the computers running. What you may not want to do is shut off high precision machines and those that need to come to temperature such as molding presses.
    Tom
  6. Likes 77ironhead liked this post
  7. #5
    Mar 2009
    Eureka, CA
    3,358
    597
    1058
    The plant I worked at had a peak usage meter installed by PG&E. Shutting down the machinery at lunch time was of course the best move, but on startup, machines were staggered so as not to peg the current inrush and incur higher costs. I think this is how it worked!
    Stuart
  8. #6
    Feb 2005
    8,532
    12041
    9670
    So you want your guys to wait for the part to be finished running.. Take it out, shut the machine down, and
    then go to lunch..
    I'm all for a flexible lunch.. I would want them to wait 3 or 5 minutes for the machine to stop running, but
    I wouldn't want them to shut it down, I'd want them to toss in another part, and then go to lunch.. Or go to
    lunch early as soon as they tossed in another part...
    Sounds to me like you are tripping over dollars trying to pick up nickels.
  9. #7
    May 2010
    Wisconsin
    384
    49
    163
    Tripping over dollars to save pennies.
    I don't know you, but I do know you ar e wasting fuckloadss of money, but it ain't from running 10 machines for 30 minutes.
    Bobw has the right idea. Run work through lunch, less deadtime.
  10. #8
    Jul 2009
    Peoria, IL
    11,055
    41
    8341
    If you want to save some nickels, run around during the lunch break and tag all the air leaks in the shop. Fix them as you can.
    Compressed air is one of the least efficient, and most expensive, forms of energy in a machine shop. I work in a lot of shops and I usually work through lunch. When the machines are idle, the typical machine shop is filled with a continuous hissing sound.
  11. #9
    Aug 2012
    Pittsburg, KS
    1,164
    88
    509
    I helped on a few energy audits at the previous job and if I recall the correct number for our area, one small air leak going 24/7 was supposed to be $1,000 in one year. One plant I helped at had over 600 hp of air compressors and we found close to 100 air leaks in one day. It would have paid that place to have one person full time keeping up with air leaks and the savings would have paid their wage and then some. I didn't get to finish that job out to see how it panned out, but best guess was they'd be able to turn off one of the 100 hp compressors and have it as a backup once all the leaks were taken care of.
    When I am running my cnc router and get to a point where I am doing something else for a little while I will kill the vacuum pump and the air, then it is just the control and drives on. My machine doesn't have an easy way to power off the drives without killing the whole thing that I know of anyway so it gets left on. If I will be gone a couple hours I'll turn it all off.
  12. #10
    Mar 2011
    Denver, CO USA
    11,508
    42
    5134
    Compressed air is a monster.
    Have the guys turn out the lights when they go to lunch.
    Fix your air leaks.
    Fix the leaks in your building.
    Make your guys eat at their benches.
  13. Likes Kiwi2wheels liked this post
  14. #11
    Jul 2006
    Hillsboro, New Hampshire
    4,729
    1062
    3258
    Many electronic devices are less tolerant of frequent switching on and off rather than just being left on. You might save some electricity, but find that after some years there's an uptick in maintenance required.
  15. Likes SND, Hitachi TS15, motion guru liked this post
  16. #12
    Norfolk England
    1,650
    1677
    1078
    Quote Originally Posted by Miguels244 View Post
    That must be the best idea ever. Especially if you work in a machine shop. Cutting oil ketchup anyone?
  17. Likes toolsteel liked this post
  18. #13
    Dec 2007
    Southeastern US
    6,265
    759
    2645
    Electronic stuff rarely goes bad when running, but shut it down and all kinds of bad things can happen. With 400+ machines in our facility, we found it much more cost effective over a weekend / holiday / long break to leave the machines on with E-stop pressed so that the lube pump / hydraulics / etc aren't running, but the control is on. When we were shutting machines off over the weekend we would often lose most of 2 shifts and sh$tloads of spare part money trying to get machines back to running. We don't shut machines off unless it is a have-to case. A card with a suspect capacitor can run for years, until you turn it off...
  19. #14
    May 2017
    FINLAND
    1,140
    303
    542
    100% agree with tonytn.
    Shutting down machinery for lunch is false economy. Electricity savings are tiny and even if nothing breaks earlier than it should even a 1 minute waiting time to boot up machines is going to cost you a lot more than the savings from electricity.
    Not sure if turning off lights for lunch break is going to save anything either.
  20. #15
    Sep 2008
    Florida
    343
    27
    89
    Quote Originally Posted by camscan View Post
    ...or to quote a sign in the break room in one of our plants "this guy is having a bacon, tomato, and lead-dust sandwich"
  21. #16
    Sep 2009
    barcelona, spain
    2,183
    445
    1228
    Yes !
    The exact same thing happens with IT servers and most-any production machinery.
    Heat kills stuff fast.
    Dust kills stuff slowly.
    Over 300+ hard drives (= servo amps on cnc machines), a temp. rise of 10C for a weekend due to air-con issues, would have 2-5 drives dead in 48 hours.
    Exactly the same over 50+ servo amps on cnc machines - heat kills them.
    But no-load drives and motors have near zero consumption - and generate near zero heat.
    If I touch the case/back of servo amps or motors that are not moving, they are cool to the touch and the meter shows == 0 usage of power.
    Say 20W for a 2.5 kW servo amp or VFD.
    Usually the fans turn off, these days.
    Quote Originally Posted by Tonytn36 View Post
  22. #17
    Oct 2005
    10,232
    17296
    5312
    He's a slave owner....
  23. Likes camscan liked this post
  24. #18
    Dec 2005
    Wisconsin
    814
    9
    102
    Switch to LED lighting. The plant I work at switched to flourescents from sodium vapor lighting. and then only 5 years later switched to LEDS (high bay). Payback was supposed to be only 1 year.
    In the shop the LEDs were inserted into the original fixtures.
    Dave
  25. Likes DyanamicEDM liked this post
  26. #19
    Feb 2004
    Staten Island NewYork USA
    3,520
    977
    1631
    I think shutting machines down for a 1/2 hour is asking for trouble with little to nothing in return.
    Tell guys to shut machines before leaving for lunch...how many will decide to not load a part several minutes prior to lunch instead of letting cycle complete, then shut down and go to lunch.
    -Expect to lose a few minutes before lunch.
    When the Gents get back from lunch, then go hit the head..get to machine and turn on, then Home...
    -Several more minutes lost.
    You save a few cents in electric for that.
    -Unless everyone turn on their machine at once spiking your demand meter...then you lose those pennies too.
    I like my CNC's to cool down a bit before shutting them down. I have the guys leave them on before they head out for the evening. Hit E-stop, clear alarm and go. The fans draw the heat out of the electronics...I like to give them a good 10-15 minutes, then go around and shut them down.
    What I like to see...gets close to lunch, toss a part or bar in and go. Let machines work while guys eat.
    If machine cycle is critical or quick...hit the E-Stop, clear alarm, give hydraulics and motors a rest leaving electronics and fans on. Pretty darn close to off in power requirements.
    But hey...different strokes for different folks.
  27. Likes Bobw liked this post
  28. #20
    Jan 2014
    Temecula, Ca
    2,056
    924
    2711
    I bet you could also save a ton of money by directing your employees to only flush the toilet after every other piss.
  29. Likes Pathogen liked this post
