I am doing some much needed maintenance on the shop and one of the things I want to do is get the shop air lines replaced. The cold has been making the spooled up lines brittle and just twisting them or stepping on the line has been puncturing them. I believe the flex lines I have are all harbor freight so I know they are bottom of the barrel already. Time for upgrades and getting the long spooled lines off of the shop floor. Nothing like 50' of line constantly being moved and used on many different machines. Getting tangled on everything.
I need to get things overhead and out of the way. I would like a few connections dropped down from above so they are just above the machines. Easy quick connection should cover 3 machines nearby.
I want to have a few locations where we can hook up to if needed nearby. I see kits online but I am suspect as they are pretty cheap.
I have a 40'x80' building and the compressor is in the corner on one end of the building. I would need 150' or so of line. Maybe 6 - 8 locations for hook ups.
Aluminum lined seems to be the way to go. I like the idea but I need to hear from people who have been there before.
