Shop Maintenance
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    Mar 2016
    1,023
    194
    304
    Default Shop Maintenance
    Shop Maintenance,
    This task can be quite a chore, but it is perhaps the most important job in a modern shop. I will begin with the hardest working tool in your shop; The Air Compressor. As was mentioned on a previous thread, a compressor failure is the worst thing that can happen to a shop. All CNC's need air, so change your compressor's oil and air filter every 6 months.
    While on the subject of compressed air, how clean is your incoming air to your cncs? If you want your mills and lathes to last 20-30 years, give them clean,dry air.
    I'm very interested in hearing your plans on this very important subject, and don't exclude any other maintenance procedures, including hydraulics and temperature control.
    Oct 2006
    Petaluma CA 94952
    621
    110
    Heres my solution, Gandner Denver dual head 10HP compressor. Normally wired to alternate between the two heads. I rewired it so whatever side you plug in runs. 100% uptime. Or if you need 20 hp of air, plug both in.
    Mar 2014
    Nebraska
    406
    42
    241
    Compressors are cheap enough in the scheme of things, just buy another before you need it. Under 10k on ebay can get you a decent used screw unit. Spend 60k-200k a pop on CNC machines but only have one compressor at the ready? Cheap insurance. We have 3 in a line and run them all fairly regularly.
    Aug 2007
    Idaho
    2,122
    643
    1020
    We use 4 Quincy piston pumps that take turns or we can pick the ones we want to run while we work on one.
  5. Likes wheelieking71 liked this post
    Virginia
    17,947
    7561
    11397
    Quote Originally Posted by kustomizer View Post
    I'm f**ked. Two for filling tires slowly, 12 VDC and 120 V corded.. or for not detonating tiny hand truck tires.
    One for bigger tires or spraying solvents or grit, even paint.
    But NO CNC goods.
    "Dear Abbey".. does the wizard of ots**t mean I am meant to bury the surplus compressors in the back garden? Or will shoving them up my arse, dry, do well-enough?
    IOW.... WTF is he smoking, NOW?
    Folk who NEED this s**t generally understand their needs and HAVE BEEN JF "dealing with all that" for more than just a day or three.
    Without some arrogant twit presuming the rest of the whole dam' world is too klewless to pour air out of the atmosphere, let alone piss out of a boot.
    Foidemore?
    We ain't exactly FAMOUS for pissing in our damned boots to begin with.
    Nor going hungry for critical-path resources, air but one of several.
    Mar 2016
    1,023
    194
    304
    But NO CNC goods.
    Foidemore?
    Does anyone understand what this drunken fool has written?
    Why has this deraigned fool be allowed to continue on this site?
    PM has a severe problem, and they do not have a clue how to fix it.
  8. Likes charlie gary, fusker, empwoer, Seaman liked this post
  9. #7
    Mar 2006
    PHILIPPINES
    3,019
    1092
    1452
    I understood it just fine. This is the "Shop Management and Owner Forum". and anyone who doesn't understand the value of compressed air in a "CNC" shop should not be in a position to manage a shop much less own one.
    This topic would have been more suited for the General thread.
    Not sure what your problem is with Therm and really don't care. This site is not the place to bring your personal problems to. You are right, PM has a serious problem and Don needs to get a handle on it soon. Ten years ago this would have been nipped on day one.
    This sight is monetary driven and this is absolutely disrespectful to Don and quite frankly the rest of us here that prefer to work with one another. With each attack you post it is just an attack on your personal character. What exactly are you trying to gain?
  10. #8
    Jan 2013
    Gilbert, AZ
    6,965
    9115
    9032
    Quote Originally Posted by otrlt View Post
    Yep, I got the jist of it. Maybe you ought give it another read. Maybe, get down of your high horse so you can see what your actually reading? IDK?
  11. #9
    Virginia
    17,947
    7561
    11397
    Quote Originally Posted by wheelieking71 View Post
    Well. he can't spell "forum", can't spell "deranged", can't tell Jiberish clothing stores from "gibberish" nonsense, WTF? Poor illiterate impoverished Fascist couldn't even spell "bullshit" off the back of only having pocket change enough to raise one "ell"!
    What makes you think he can read if-even he could be convinced it worth the adult education remedial reading course as preparation?
    "The World Wonders"
  12. Likes BLAZINGFIEND420 liked this post
  13. #10
    Jun 2011
    New Jersey
    1,401
    761
    586
    Dad had an air dryer for the compressor, as well as a water trap just underneath. Literally GALLONS of water would pour from the dryer.
  14. #11
    Virginia
    17,947
    7561
    11397
    Quote Originally Posted by DouglasJRizzo View Post
    Ancient Persia built "high-topped shoe" shaped "wind towers" wherein the flow of night air at minute variations in pressure from what would thousands of years LATER become known as the "Bernoulli effect" chilled the air and coated the stone walls with rime ice.
    Which was then scraped-off the stone for making "sorbet". SF writer Frank Herbert picked-up on dry environment tricks of that sort when he wrote "Dune".
    Problem was, the air that carried the moisture was also laden with biologicals.
    Tuberculosis among them.
    Progress always exacts its price SOMEWHERE along life's journey!
  15. Likes jptech, BLAZINGFIEND420 liked this post
  16. #12
    Sep 2006
    Sacramento County, California
    4,292
    2737
    1641
    Ha, you want to get rid of Thermite first? That's a laugh. There are abut 40 to 50 that should go before him....not namin' names, mind ye, but just considerin' the thousands of posts that I've read here in the past 14 years, he's one of the less guilty. He'd be a "misdemeanorist" and the others felons. I'm just sayin'
    Damn, I'm starting to sound like Thermite now......sheesh
  17. #13
    Apr 2005
    Beaverdam, Virginia
    9,747
    1375
    5082
    The ignore feature works great, the only time it doesn't work is when the person you want to ignore is a mod or the ignoree gets quoted. Fortunately the mod I wanted to ignore is now gone. As for air compressor I could not fathom someone not having a back up. I had two air compressors before I even had a shop, mostly used for working on cars.
  18. #14
    Nov 2016
    North Carolina
    240
    74
    121
    Here's a theory: the posters that draw the most ire like AS9100 and otrlt are actually PM management hired plants who are instructed to annoy everyone into replying. And then the replies/veiws= sponsor money.
    Why else would otrlt come on here?
  19. #15
    Apr 2005
    Beaverdam, Virginia
    9,747
    1375
    5082
    Quote Originally Posted by LOTT View Post
    I think the only one that fit that bill was GBC, especially when they made him a mod and he kept trolling. AS9100 is a mentally ill con man, and for otrlt just a case of a machinist with a big ego who gets their jollies out of bragging about how much better they are than everyone else to a point where it because a big part of who they are. No idea why someone would do that to a bunch of strangers they most likely will never meet. Self promoting doesn't earn you squat here. Actions speak louder than words. Actions like Vancbiker who has probably by now saved fellow members 100's of thousands of dollars in service calls.
  20. Likes TeachMePlease, gregormarwick liked this post
  21. #16
    Jan 2003
    Canada
    11,540
    6284
    3695
    Screw compressor with good air dryer. That oil's good for years.
    #1 thing to keep good track of is batteries. I got a list behind each machine of battery types/part# and when last changed and I usually check voltage in and out.
  22. Likes N/A, Garwood liked this post
  23. #17
    Virginia
    17,947
    7561
    11397
    Quote Originally Posted by Newman109 View Post
    No surprise.
    I was taking a measure of inspiration from YOU..
    In trying to strike a better balance between shop floor and lifetime "A+" English student who enjoyed "playing" with the language!
    I MAY even turn the spell checker back on and invent fewer words?
    Nah. Has to be SOME fun left in it!
  24. #18
    Aug 2007
    Idaho
    2,122
    643
    1020
    I never thought much of a person that could only come up with one way to spell a word, that would be total lack of creativity causing ones brain to get stuck seeing only part of what is placed before them.
  25. Likes Newman109, Ox liked this post
  26. #19
    May 2019
    Michigan
    2,522
    1403
    1918
    Can anyone tell me why threads seem to degenerate so quickly anymore? I can't remember it ever being so bad when I was lurking or first joined.
    Sheesh, this one isn't even on the second page yet!
    Most of us are adults here...(I hope). Could we all begin to act our age??
  27. #20
    Mar 2014
    Nebraska
    406
    42
    241
    Ironic I posted this while in another thread, a shop owner was dead in the water with no backup air compressor...
