Stirling
Hot Rolled
- Dec 11, 2013
- Alberta canada
I've often found heavy resistance offering design/feature changes to customers that would improve a product or simply improve manufacturability.
Ill use an example of a part to highlight my current situation:
a customer ask me if I can make a big ugly sprocket for them. Sample pc. is a simple shaft with keyway, with 3 torch cut plate sprockets welded together and onto the shaft (seriously nasty) the sprocket is run dry against another sprocket in a crude device. I have offered a cnc machined sprocket out of pre hard 4140. customer likes it. I've made a few now. thinking about it I propose an improvement offering not welding it to the shaft, but using a interference fit to lock it to the shaft. this makes the shaft or sprocket exchangeable when worn, while not weakening the shaft with weld. I have done this with most multi thousand HP electric drives, including with recip loads. right now he hates the idea. I feel he simply does not understand the concept (oilfield, always a bigger hammer, weld everything is the attitude in our region)
any tips on getting my message across?
I run into this with even simple things, AKA, would you consider a larger pocket corner radi in this deep pocket. ( I know its simply clearance) I feel like ive lost a job or 2 over this kind of thing, simply trying to help
